20 Most Recent Canon PowerShot SD790 IS Digital Camera Questions & Answers
0answers
2answers
Replacement screws
FYI I just called Canon (1-800-828-4040) about the screws.
They are sending 2 screws out to me free of charge "as a one time courtesy."
Perhaps they got lots of complaints.
Thanks for your help
Mitchell
3/13/2014 11:28:45 PM • Canon PowerShot... • Answered on Mar 13, 2014
0answers
0answers
2answers
I have forgot my password...do
I don't think the Canon SD790 IS camera has a password. =)
If you mean your Fixya password, then there is a "forgot my password" link on the login page.
Hope this helps.
Thomas Drayton,
Owner, Darntoothysam.com - Online Digital Camera Repair
8/17/2012 3:39:41 AM • Canon PowerShot... • Answered on Aug 17, 2012
I have the SD790 IS,
The SD790 has a problem with the power button and sometimes the zoom switch, thankfully they are on the same assembly. You can get a new part for $35 incl shipping, or have it installed for just $30 more.
Another design flaw of this camera is:
If you haven't checked the screws recently on the handstrap side of your SD790 to make sure they are tight, I would advise doing so. Actually, take them out and secure them with Locktite, because if you don't they will fall out and the whole side of your camera will fall off.
If you need the zoom switch replaced, I happen to know the shop linked below would check and secure your screws for you at no additional cost!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
7/12/2011 12:53:54 AM • Canon PowerShot... • Answered on Jul 12, 2011
Canon sd790is screws
Why not try a place where they repair jewelry and watches?
7/12/2011 12:27:07 AM • Canon PowerShot... • Answered on Jul 12, 2011
My canon poweshot SD790 IS
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
6/26/2011 10:47:00 PM • Canon PowerShot... • Answered on Jun 26, 2011
When I play back video. It only plays super fast.
This occurrs when youu have the recording setting on time lapse with no sound. All you can do is to set the recording on to standard by turning the round wheel at the back of your camera.
5/12/2011 12:18:39 PM • Canon PowerShot... • Answered on May 12, 2011
Sometimes when I go to download my photos to my
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program.
4/11/2011 6:00:36 PM • Canon PowerShot... • Answered on Apr 11, 2011
No upload
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
3/31/2011 5:57:09 PM • Canon PowerShot... • Answered on Mar 31, 2011
I cannot format my brand new SD card with my Canon
Try another type of SD card as the Canon camera are very choosy with regards to SD card. All I want to say that, not all SD card will work on Canon camera. Or if you insist of using your SD card you have to format it in your computer using Canon formatting software which is downloadable in the website.
3/9/2011 3:42:38 AM • Canon PowerShot... • Answered on Mar 09, 2011
Lens Error message Canon SD790is camera, lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
12/12/2010 5:48:24 PM • Canon PowerShot... • Answered on Dec 12, 2010
How do you unlock your card?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
11/19/2010 4:25:09 PM • Canon PowerShot... • Answered on Nov 19, 2010
How do i donwload pictures onto my computrer? I
The camera should appear as a removeable disk drive in the Windows "My Computer" menu. Treat it like any disk drive, and drag and drop files to get the pictures onto your desktop. There will be a directory or to to go down into to find them.
10/25/2010 6:30:22 PM • Canon PowerShot... • Answered on Oct 25, 2010
Canon PowerShot SD790 IS Digital Camera Logo
60 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
canon poweshot sd790
  • Cameras
