20 Most Recent
Leviton Combo Switch Neon Lght - 5226-I - Ivory Questions & Answers
Lg Neon not reading external
I think putting the card in and out of your phone may have slightly changed the alignment of the card to the connectors in the phone - try entering the card either to the left a little or the right but i have a feeling contact is not being made from the wear and tear. Does the card work in another phone? if yes then definitely not the card... but the fact that you have tried to use 2 different cards im thinking its the phone :(
Lg neon memory card wont read
i have the same problem with this phone (along with many many others) sorry to tell you this but this phone is just a piece of JUNK! with many problems and i dont think theres a way of fixing them. i wish i would have known before i bought it :(
I have a 5226 neon switn single pole and how i
Yes, but only to operate the neon light. The switch will operate without the neutral. You should have two neutral wires in the box, one in, one out. Besides connecting the IN neutral to the neon light, it must also be connected to the OUT neutral so that your lamp or appliance has a neutral. There might be two silver screws on the switch already connected together for this purpose.
Dont Know Where??
Most LG phones have a spot for the memory card behind the battery. Remove the battery and you will see where the memory card slides in.
Lg neon not reading memory card
i haad the same problem this is what i did..
Firts i downloaded the songs i wanted in limwire
then i made a folder on the desktop and dragged them to the folder
then i went into MY Computer and opened the folder that said sounds in there i made a new folder
then i dragged the files from the folder on the desktop to the new folder in sounds then i put the memory card back into my phone and the songs were there..
i felt so stupid after because it is so simple and i just couldnt figure it out
play around with it you will get it
hope this helps :)
I cannot turn off light that uses a Leviton Cat /no 16400, DHC switch not can i find the receiver box that controls the lights
A Leviton DHC receiver device can look like any other switch or receptacle so if you didn't install it or not provided a map then you'll need to locate it.
Likely the wall switch that originally controlled the light was replaced with DHC device and paired with the 16400 at another location. If you can't identify it, then removing face plates and devices may be the only practical method to locate it.
If your not comfortable with removing devices safely, hire an electrician.
https://www.mc-mc.com/ASSETS/DOCUMENTS/ITEMS/EN/Decora_6375_Catalog.pdf
7/5/2021 2:59:40 PM •
Leviton...
Answered
on Jul 05, 2021
