20 Most Recent Generac Guardian 065795 - battery charger rectifier Questions & Answers
Generator problems
yes but battery charge voltage has to be 14.5-14.8 volts to charge a battery batteries are known to be 12 volts but in fact at 2.2 volts a cell they are 13.2 volts capacity so 13 volts will not charge a battery
4/14/2017 8:18:14 AM • Generac Guardian... • Answered on Apr 14, 2017
If I run the generator for several hours it will
Check the battery voltage before you start it at the generator. IE 12V start the generator and measure again. It should be around 13.8V if it does not rise, go to the charge rectifier in the genset and make sure you have AC going onto it. (Assuming you have the gen battery charge option) If you don't have ACV you can suspect the B stator windings, if you do have AC. Check the rectifier DC output 13.8V if present check wiring and fuses, if not present change the rectifier, note where the wires go ! The battery is dying because the ignition system of the gen is pulling it down and it is not charging.
11/17/2013 3:18:08 PM • Generac Guardian... • Answered on Nov 17, 2013
The oil pressure drops after 20 minutes, trips on
sound like the crankshaft or oil pump may have issues I would go for crankshaft as this is where the oil pressure is created and once warmed up the oil becomes thinner and will escape from warn bearing easier
11/4/2013 12:51:33 AM • Generac Guardian... • Answered on Nov 04, 2013
I have a automotive battery charger thats a
if you can find out the current it takes you can go online and buy rectifiers all day long they are pretty cheap too also you need find the type of rectifer like full wave, half wave, bridge rectifier. the bridge is usually the most common tho.
11/12/2010 12:19:33 AM • Generac Guardian... • Answered on Nov 12, 2010
2nd battery explosion with 3 year interval of flawless operation.
If the unit is using a wet cell acid battery, it's possible that dirt mixed with hydrogen build up on top of the battery caused the second failure. The battery top should be kept clean and should be checked at least 4 times per year. Any stray ignition source can cause the hydrogen to explode, including lightning.
It's also possible that the battery float charger needs to be adjusted or possibly has a problem. Some float chargers are adjustable. The higher the charging rate the more off-gassing the battery will experience and increase the chance of a failure.
If the battery has exploded, the entire generator and housing should be cleaned (washed) thoroughly to remove any remaining battery electrolyte (acid).
Be careful - if you aren't comfortable working on this type of equipment, it's best to call a local dealer and find a service vendor.
7/7/2010 3:10:09 AM • Generac Guardian... • Answered on Jul 07, 2010
How can i fix my rectifier
Replace the part. The part is not repairable if blown.
3/23/2010 5:05:42 AM • Generac Guardian... • Answered on Mar 23, 2010
Over charging? blew up battery
Battery charger should be putting out between 12.5 to 14.5 VDC...Battery blowing up is typical in that generator because it is on a constant trickle charge and the battery will go dry faster than normal. Make sure you check battery level every 6 months and replace every 2 years.
11/22/2009 5:25:51 AM • Generac Guardian... • Answered on Nov 22, 2009
Generac 20kw - new battery dead, twice. is there a
if this is a standby unit. there is a charger built into the control box. check the fuses. if it still blows the d\fuse you can install a float type charger available from most auto parts stores. make sure there is power comming in from the bldg breaker box.
8/12/2009 3:53:35 PM • Generac Guardian... • Answered on Aug 12, 2009
No electrical output
It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
5/12/2009 10:59:27 PM • Generac Guardian... • Answered on May 12, 2009
Generac Guardian 15kw pn 43903 sn 4067938. Battery not charging. How do I get to the voltage regulator?
I believe the charging circuit is part of the main controller board. The board controls the relay that cnnnect the battery to supply power for start and for charging. Check to see if the relay is good.
7/26/2022 5:04:21 AM • Generac Guardian... • Answered on Jul 26, 2022
There is no spark to the plugs on my generac 12000 watt generator,i replaced the plugs and still no spark,any help would be appreciated.
Unplug the oil sensor.
The oil sensor is located behind the oil filter. I unplugged the oil sensor and it fired right up. Plugged it back in and it runs fine.
It might be because it is cold.
I don't know why but I turned it off and it starts right up now.
12/23/2020 7:11:24 PM • Generac Guardian... • Answered on Dec 23, 2020
2answers
Keeps giving me warning charger missing on generac generator
The charger might be bad and you should get a new charger
11/28/2020 9:00:49 AM • Generac Guardian... • Answered on Nov 28, 2020
Control board has no lights
Likely an extremely low or dead battery.
10/15/2020 10:12:55 AM • Generac Guardian... • Answered on Oct 15, 2020
Generac Guardian 065795 -  battery charger rectifier Logo
18 questions posted
Top Generac Guardian Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Generac Guardian Electrical Supplies
Most Popular Question
2nd battery explosion 3 year interval
  • Electrical Supplies
