20 Most Recent Honda EU6500iS Inverter Generator Questions & Answers
Check if there any alarm on monitor by pressing button several times. It has code like E-number. Replace spark plug, fuel filter. Clean carburator, spark arrester. Check wiring of thermosensor.
Honda EU6500iS... | Answered on Apr 28, 2017
perhaps it is too small for the task you are giving it .
Honda EU6500iS... | Answered on Nov 26, 2015
How To Replace The Starter Rope On Your Recoil ...
? 4:47
www.youtube.com/watch?v=Q3NjVomUQJM
Feb 25, 2009 - Uploaded by craig1974 Me showing you how to replace your starter rope on your recoilassemblies.
Honda EU6500iS... | Answered on Sep 15, 2015
If you run 12volts to the carb, will it run? I assume since it has no power at carb as you stated, that it has a fuel shut off at carb and will need voltage to activate magnet.
Honda EU6500iS... | Answered on May 25, 2014
this sounds like a capasitor/resistor that is getting hot under load once it is switched off and cools down it works until it gets hot again similar to that of a cars ignition coil which will get hot and cut the vehicle out but once it cools it will start again.
Honda EU6500iS... | Answered on Dec 07, 2013
If you need more support, we recommend you a support website, you can search your answer on the website: www.dieselgeneratortech.com
Honda Electrical... | Answered on Oct 15, 2019
If you need more support, please visit www.dieselgeneratortech.com
Honda Electrical... | Answered on Oct 10, 2019
For your question, i have replied many people, why generator set can start but not generate electricity?
Here is some reasons for reference:
1.After the diesel generator is stopped, the residual magnetism is often lost, because the material used for the magnetic pole of the exciter is close to the soft steel, and the residual magnetism is small. After the shutdown, when there is no current in the excitation winding, the magnetic field will disappear.
2.The magnetic pole of the diesel generator loses its magnetic properties.
3.Damage of excitation circuit components or circuit breakage, short circuit or grounding phenomena.
4.The exciter brush is not in good contact with the commutator and pressure of brush holder is insufficient.
5.Excitation winding wiring error, opposite polarity.
6.Stator winding and rotor winding of generator set open circuit.
7.Poor contact between diesel generator brush and slip ring, or insufficient brush pressure.
8.Diesel generator lead wire wiring is loose or switch contact is poor.
9.The fuse box is fused.
10.The "auto-manual-de-excitation" switch on the control panel is in the de-excitation position (automatic generator set has "auto-manual-de-excitation" switch).
11.The voltmeter is damaged.
12.Rotary rectifier module is damaged.
Honda Electrical... | Answered on Oct 09, 2019
Most of the time it is either the Capacitor or AVR that has blown (depending on what is fitted on your generator.). Check out our videos on how to test them.
We hold a full range of Generator AVRs and Capacitors. https://www.generatorguru.com
We have a whole Help Center and Engineers dedicated to helping people fix their Portable Generators. In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
Honda Electrical... | Answered on Aug 19, 2019
I think there is overload .kindly measure ur load of consumption. Do not run the generator set with high load it can be cause of circuit breaker Tripp off .
Honda Electrical... | Answered on Jul 27, 2019
you probably have either a bad capacitor or more likely a short stator winding due to previous overloading
Honda Electrical... | Answered on Jun 03, 2019
Verify that the double gang circuit breaker is good on both sides. Check for loose wire on breaker or receptacle.
Hi!
We have a put together a guide here to assist you in these situations. It will guide you through testing and repairing the Generator. : https://www.generatorguru.com/need-help/
If you need any further help our Generator Engineers are happy to assist you.
Regards,The Generator Guru Team
Honda Electrical... | Answered on May 31, 2019
use your car battery and jump it. you cannot get too big a battery. big is better.
Honda Electrical... | Answered on Apr 10, 2019
Honda EU6500iS Inverter Generator Logo
13 questions posted
Top Honda Electrical Supplies Experts
John Trevino
Norman Al-Anbar
Sheldon Dedek
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electrical Supplies
Most Popular Question
stops generating just idles
  • Electrical Supplies
