20 Most Recent Honda Mmd 5000 Watt Generator W/ Engine Ngk 6000H Questions & Answers
you need to tie into the 220 voltage at you breaker panel... 5000 watts will barely power your heater. you will not be able to power it direct as it needs low voltage for the control... but I am not an expert
Honda Mmd 5000... | Answered on Dec 28, 2013
Hi, Check the on/off switch is set to on. replace sparkplug check magnedo. Good luck.
Honda Mmd 5000... | Answered on Aug 04, 2011
7 horsepower is approx 5150 Watts so the compressor would be taking this power while running. On startup however the compressor can take a surge of upto 3 or 4 times this power so the generator wouldn't be able to supply this demand . In any case it's not advisable to run a compressor off a generator unless the generator is high powered, 20KVA or greater for 7hp.
Honda Mmd 5000... | Answered on Mar 31, 2011
Plugged air filter, plugged exhaust or oil is old or not light enough wait.
Honda Mmd 5000... | Answered on Sep 02, 2010
try spraying starting fluid in to carb and crank away,itf it woirks then youi need carb work,if it does nothing then check the spark, then the comprussion, should be over one hundred
Honda Mmd 5000... | Answered on Dec 19, 2009
it may be running far to fast, just slow it down a little
how did you get this reading,,,on load or off load???
if off load hook up a light bulb and take another reading,,if its pulled the volts back down thats fine,,,if not plug in to the geny some thing thats close to its full load,,,"not more than this" now take the reading,,,
if still high lower the reves till its just 120v on full load
mind you,,,5000watts? thats a big un!!!!
Honda Mmd 5000... | Answered on Nov 19, 2009
The Choke's function is to limit air intake till engine reaches opperating temperature.It should decrease to nill if auto.If not then try increasing the idle.Good Luck.
Honda Mmd 5000... | Answered on Sep 17, 2009
If the doides have a number on them, goto www.nteinc.com and cross reference them to a good number. Then you can find a dealer on the web site also.
Honda Mmd 5000... | Answered on May 11, 2009
you probably have either a bad capacitor or more likely a short stator winding due to previous overloading
Honda Electrical... | Answered on Jun 03, 2019
Verify that the double gang circuit breaker is good on both sides. Check for loose wire on breaker or receptacle.
Hi!
We have a put together a guide here to assist you in these situations. It will guide you through testing and repairing the Generator. : https://www.generatorguru.com/need-help/
If you need any further help our Generator Engineers are happy to assist you.
Regards,The Generator Guru Team
Parts Spares for Generators and Small Engine Machinery
Honda Electrical... | Answered on May 31, 2019
Honda Mmd 5000 Watt Generator W/  Engine Ngk 6000H Logo
21 questions posted
Top Honda Electrical Supplies Experts
John Trevino
Norman Al-Anbar
Sheldon Dedek
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electrical Supplies
Most Popular Question
reading 120 volts accross red black
  • Electrical Supplies
