20 Most Recent
Jacuzzi T362-969 Tru-Level 42 X 36 Shower Base, Oyster Questions & Answers
I purchased a very nice and expensive jacuzzi 60
some shower bases require additional support,I would call jacuzzi and explain the problem.If 6the unit required more bracing you will probably have to reach the contractor who put the unit in,then go from there,but this day and age it is hard to get satisfaction cause no one wants to be liable for labor and product.good luck hope you get satisfaction from one or the other!
The on off light in my Jacuzzi whirlpool bath keeps flashing
The flashing on/off light in a Jacuzzi whirlpool bath may indicate an issue with the control system, and it's important to address the problem to ensure the proper functioning and safety of the whirlpool bath. Here are some general steps you can take to troubleshoot the issue:
1. Check the Power Supply:
- Ensure that the whirlpool bath is receiving power. Verify that the circuit breaker for the whirlpool bath is not tripped, and check for any loose or disconnected power cords.
2. Inspect the Control Panel:
- Examine the control panel for any visible issues, such as loose or damaged wires, connectors, or buttons. Ensure that there is no water or moisture present in the control panel area.
3. Reset the System:
- Some whirlpool baths have a reset function. Turn off the power to the unit, wait for a few minutes, and then turn it back on. This can sometimes reset the control system.
4. Refer to the User Manual:
- Check the user manual that came with your Jacuzzi whirlpool bath for specific information on troubleshooting and resetting the control system. The manual may provide insights into the meaning of the flashing light and how to address it.
5. Contact Jacuzzi Customer Support:
- If the issue persists and you cannot find a resolution through the manual, contact Jacuzzi customer support or the manufacturer for assistance. They may be able to provide guidance on how to troubleshoot and resolve the issue.
6. Professional Inspection:
- If you're not comfortable or able to identify and fix the issue, it's advisable to seek assistance from a qualified professional or a technician experienced in Jacuzzi whirlpool bath systems. They can perform a thorough inspection and diagnose and repair any electrical or control system problems.
It's essential to prioritize safety and follow proper procedures when dealing with electrical components and water. If you're uncertain or if the troubleshooting steps don't resolve the issue, it's best to seek professional assistance to avoid potential hazards.
12/17/2023 11:37:18 AM •
Jacuzzi Home
Answered
on Dec 17, 2023
My Jacuzzi bathtub won't start-188 error code
Please attempt to start the jacuzzi without any water and see if it functions. Then you can fill the jacuzzi up to 1/4th with water and check if it continues to run. If so, continue to one half full. If this jacuzzi breaks down at these water levels, then you'd need to call the manufacturer to advise on what part needs to be changed to get everything working again. Thank you.
8/21/2022 9:40:54 AM •
Jacuzzi Home
Answered
on Aug 21, 2022
Jacuzzi toilet continually stops and starts during refill
Several things can cause this problem- if you post a picture of the inside of the tank so we can have a good look at how the fill/stop mechanism operates that would be great. We could more than likely identify some type of problem and solution. Not all flush/fill mechanisms are not the same but thats surely where your problem is UNLESS its in your water lines. I would love to help you just please provide photos and as much information as you can.
Mr.Mike
5/20/2020 5:32:45 PM •
Jacuzzi Home
Answered
on May 20, 2020
2007 Jacuzzi J355 will not heat
If there is power to the unit, most likely it will need to be replaced. Check for reset button, and check the fuses before replacing the unit.
5/23/2019 4:22:08 PM •
Jacuzzi Home
Answered
on May 23, 2019
Re-set button on jacuzzi motor?
Should be one on the motor and also check to see if there is a GFCi somewhere too. Could be around where the jacuzzi switch is.
2/10/2019 6:29:29 AM •
Jacuzzi Home
Answered
on Feb 10, 2019
