20 Most Recent
Gateway NV51B35u Dual Core E-450 4GB 320GB 15.6 LED DVDRW 802.11N HDMI Windows 7 Questions & Answers
System disabled [01435]
Brian Wells wants more answers to this question
Brian start your own post
tell what PC you have, nobody did yet
why hyjack posts that fail at least that fact.
or go to gateway forum
google gateway forum
is this heard, ?
ask the maker to help you fix this.
on most forums this is an ******* post now. hacking passwords
so keep that in mind first. ok, things changed in last 5 years.
and learn to go to Gateway.com and contact them directly.
they will (by laws now) be forced to make you prove you own it.
LAWS, in usa NIST and DOJ and in Europe too.
history 101:
some very PCs old had jumpers.
then later back door passwords, now 2018 those are *******.
and last , none of the above allowed, by design, 2018., only the maker can help.
on newer PCs from about w8 introduction UEFI rules.
Can I get disks I lost to reload my gateway nv55c laptop?
penguintech
October 18, 2012 9:36:23 PM
what are you trying to do? if your trying to recover from the partition and it is not allowing you to do so, you may have corrupted the restore partition. or you let the 30 days expire and you have no choice but to reinstall or purchase a legal license. Either way, it may be best to contact gateway for original disks (usually a minimal fee) and once your back up and running, make sure you make a set of recovery disks before you do anything else.
Why replacement harddrive wont install operating software
If it is a new hard drive it could need formatting or if it already has software loaded it could need the drive formatting on a different machine.
I have noticed something strange, probably in the bios settings of one computer I had contact with recently. It resisted all attempts to load an operating system on an empty drive but loading an operating system with a different machine and then reinstalling the drive in the original it accepted the new operating system without any further hitches.
Another thing to think about was the time we tried to take a look at a hard drive and all my friend's machines refused to read it.
It turned out his machines had 32 bit operating systems and the fresh hard drive was on 64 bit.
Re-factory reset
Okay, whats happened is that you either have a program like Bitlocker turned on, or some security feature enable on your hard drive.
If you want to get into BIOS press either F4, F2, F1 or DELETE. Most of those keystrokes will enter you into your BIOS. Unless your BIOS is locked with a password, in which case you'll need to get a device code. If this is the case you will need to contact the manufacturer and speak with them about your issue, which will require your serial number and model number.
As a back door last resort, you may be able to put your Windows OS disk and do a install over the existing Windows image. Make sure you have a real windows OS disk, not a recovery disk. Let me know if any of this helped you.
