Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
Posted on Mar 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Scanner of my MFC 490CW does not work, even though the Printer does work. When I press the Scan button, I receive the message CHECK CONNECTION. This does not make sense, since the connection between my computer and the printer must be working if I can print. The list of Scanners and Cameras in the Control Panel is blank and remains so after I press the Refresh button. I have tried (i) reinstalling the appropriate driver for a Windows 7 64-bit operating system from Brothers website, (ii) switching off and on my laptop and printer, and (iii) unplugging and replugging the jacks to my router and printer, all to no avail. The Brother operating manual does not provide a description off what to do when the message CHECK CONNECTION appears. Please tell me how to fix the problem.
Jim Keysor
Level 2:
Sergeant:
  • Expert 331 Answers
  • Posted on Mar 28, 2017
Jim Keysor
Expert
Level 2:
Sergeant:
Answers
331
Questions
Helped
83876
Points
605
Install the Brothers Paper Port program and see if that helps. Usually comes with CD you have with machine but can be down loaded...
5 Related Answers
tniver
  • Posted on Apr 16, 2009
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Anonymous
  • 55 Answers
  • Posted on Jun 30, 2009
SOURCE: Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
Anonymous
  • 7 Answers
  • Posted on Aug 27, 2009
SOURCE: NO CONNECTION (LAN) on Brother MFC-440CN
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Anonymous
  • Posted on Mar 07, 2010
SOURCE: MFC-440CN: Prints but does not scan
Go to system/computer control panel, select "scanners and cameras". you should see your brother system in there (if u were able to print to it but not scan). Right click on it, select properties, and select "Network Properties" Tab. Choose select "specify your machine by address" rather by "by name". Most home/home office users dont have a local domain server at home, so even though your printer was named, it cannot be located by tcp-ip using the name, but rather by ipaddress. This solves the issue.
Anonymous
  • 87 Answers
  • Posted on May 05, 2010
SOURCE: my brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
How do I use my MFC-7860dw printer as a scanner. It has worked in the past but says ""check connection"" now. It will print and copy.
I have a mac and I can't just hit the scan button. I need to go through my settings to my printer. Then when I open the MFC printer I have to select print or scan and operate from that window. I have never been able to do anything right from the scan button on the machine
How to scan a picture from my printer to my pc i did it one day and i can't remember what i did i thought i did the same thing the printer is a brother mfc-490CW
Hi
2 way on how to scan.
1. Put the document either in the top feed or in the glass scanner. Press SCAN button in your printer and then navigate and choose save AS PDF or OCR or FILE.
2. Go to the scanner icon located in your computer and then put the document to be scan and then press scan button.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
MFC-490cw Color Inkjet Multi-Function Printer: how to send a fax...
Most of these will send a fax without even using the PC. Just connect a phone line, place the document in the proper position, usuallu print side up on newer models, and push the fax button, it should prompt you for the number. Once dialed,, the paper will feed into the scanner portion of the multi, and you will see it on the menu bar saying sending page 1, 2 etc, after if is done sending, it will dial and connect, yu should hear the typical noise a fax makes. then it will say fax sent or end or something similar, that's it, try sending one to a friend to make sure it's working. Now some simpler machines require you to open the scanner portion and lay the paper down in the glass manually, mine does it both ways. In that case just skip the feeding part, and dial wait for it to scan and send.
1helpful
My brother mfc-490cw I can't send or recieve faxes.
6helpful
3answers
My scanner/faxer won't scan for my mfc-490cw brother product. I always have to reset it and push 20 buttons so I don't remember how to do it. Can you help?
I have the same problem. It was working fine, then after not using it for a few weeks, all the sudden I couldn't scan. I'm hooked up wirelessly through my router. I can initiate a scan both from my PC and from the scanner itself, when initated from the scanner my PC responds and shows the progress bar, and the scanner actually scans. However for some reason no data is being sent back to the PC. And after a few minutes I get an error message saying that communication was lost (or something like that) error TW007. Yesterday I called into brother support and was on the phone for an hour and a half. they walked me through verifying connectivity, uninstalling and reinstalling the software and drivers, but to no avail. In the end we made no progress. I can print without a problem, and fax and photocopy. But for some reason it seems that the scanner is not transmitting the information back to the computer, even through the connection was established and the computer is waiting for the data.
1helpful
Display reads "connecting to PC" nothing happening
Was this function working fine before? When you choose Scan => To Email, what the device actually do is launch the scanning software and scan it and save to temporary folder THEN open your default OUTLOOK email account and creates a new mail with the scanned file attached to it. So it could be a scanning software error or low in memory since the process requires an amount of memory.
So you better try to Scan => To File and see if the scanning completes. If you have problem with it, then try to reinstall the program of your printer and scanner in one.
2helpful
I try to scan and it says check connection
Is it set up to scan to a file on a computer or are you simply scanning to fax.By the error message its looking for a location to dump the files or pages it has scanned.Look at your destination.
good luck
30helpful
5answers
MFC-665CW Scanner keeps saying Connection Failed
I think I solve the issue for scanning so far. Here's what you do goto control panel -> Scanners and Cameras. Then right click into propertise, then check Specify your machine by address. It should already have the printer IP address listed in the box below. If not our can goto to your router and see the ip in the DHCP Client List .
After this I'm able to use the Control Center 3 scanning.
I think the problem was the NODE name list in the setting in my winxp pro does not match the actual NODE name the printer is using.
Norman Weimar
Norman Weimar
k24674
