Keurig Platinum B70 Coffee Maker Logo
enrique vazquez Posted on Jul 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have my coffe cap set at a large cup and only give me about a 1/4 of cup of coffe . gives me a de scale message on the screen.
Anonymous
Level 3:
  • Keurig Master 43,501 Answers
  • Posted on Aug 07, 2011
Anonymous
Keurig Master
Level 3:
Answers
43501
Questions
0
Helped
10845257
Points
101584
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
3helpful
De scale kruig coffe maker
Empty the reservoir of water and fill it with four (4) cups of white vinegar. Run the Keurig WITHOUT a K-Cup until the vinegar has been run through. Rinse out the reservoir with hot water, dry it, then fill with cold water normally used to make coffee. Run the maker 3 times, or until vinegar taste disappears.
DESCALED 2X'S STILL WON'T WORK.LARGE CUP ONLY 1/4 COFFE IS MADE. WATER RUNS BACK IN TO SUPPLY.
heatman101
2helpful
1. It sometimes doesn't give me a full cup as per the setting. 2. It was hardly working and I descaled with vinegar - it worked while I cycled the vinegar through but then quit working entirely
If your brewer is not brewing the full amount selected, it may be caused by the following:
The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Then try also this
http://www.youtube.com/watch?v=DqRs4Ott21s
When brewing a cup of coffee,the maker is not brewing a whole cup....and on the screen it said de-scale
heatman101
I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
To begin, you will need the following:
  • 48 ounces of undiluted white vinegar
  • Large ceramic mug (do not use a paper cup)
  • Access to an empty sink
PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
Once k cup is inserted and process begins; it drips all over without making the coffe. Need help
sdfsdf
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
"not ready" frozen on screen
Try to unplug and plug back in..plus follow the below
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
2helpful
Takes too long to brew and only small amount brews even when I set it on large setting
21m12mSorry to read about your issue.
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
