20 Most Recent
Keurig Platinum B70 Coffee Maker Questions & Answers
Keurig water disappearing
I'm not sure if this is what you were referencing, but i feel like my Keurig makes water magically disappear. I will look at the tank and see PLENTY of water, but when i come back 15mins later to grab the cup i find that it didn't brew at all and the water level is now depleted. Where did it go? It's not leaking out, as my counter is still dry. I have searched google numerous times over the years and cannot figure out where all the water goes.
Water does not come out of the brewer. It spits
The most common cause is that the unit has become calcified. Follow your owner manual for descale the machine, lacking that, pour a 50/50 mixture of white vinegar and water (because your machine is clogged, you could consider using 100% vinegar) into the the machine, run so that some (get as much as possible) of the weak acid mixture has been pulled into the internal water path and then shut off and leave sit. because of the large degree of scale buildup, I would leave at least overnight, if not longer. It will take a considerable amount of time for the vinegar to dissolve the hardened calcium. After allowing the vinegar to work, restart the coffee maker and allow the remainder to pass through the machine.
After cleaning, run a full pot of plain water through the machine, one full cycle, no coffee) to clean out the residue.
Will not fill cup and descale light stays on have
We have a Keurig ourselves and were stumped when we first saw that descale message on the brewer. There are a number of ways to descale a brewer, the least expensive being to run some vinegar through the machine a couple of times, and then run cold water through a few more times to rinse it.However, simply trying to clear the lines often doesn't work. And as you will see from the many comments below, by far the most reliable way to get your Keurig brewer working again is the "Slap and Burp" method.Here is how you do it.First, unplug the brewer and remove both the water reservoir and drip tray.Next, hold the brewer upside down over the sink and slap the base a few times. And I mean really slap it.Now put everything back together and try brewing again. Most of the time this works with a couple of good slaps. If not, try it again.And don't worry, there are no laws against giving your Keurig a good slapping!Good luck!
HOW TO DISABLE AUTO ON/OFF
Sorry to read about your problem, I hope this helps you out.
when you goto your menu, you will see auto off/time use the hour button, then select off
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
My keurig says Not Ready and won't brew
Push the 2 buttons next to menu at same time then press menu. Wait for keurig lights to blink then release buttons. You just reset your keurig. Turn on and enjoy.
