Hi licah,
It seems that your computer is not booting into windows properly at all.
You mentioned you see Lenovo and windows appear then the screen goes Blank afterwards, you can try to Boot directly into the Hard Drive manually just to get everything working or I mean Booting up again but this is a small shot from what you are experiencing but is also worth the try.
turn your S10 machine OFF then turn it back ON and keep on tapping f12 on the keyboard you should see Boot menu on the list Select HDD then press enter this should boot into the Hard Drive, if it does not then you may need to send the system back to Lenovo for a possible reinstallation of windows or on most time we also have the Hard Drive replaced in many cases.
I hope that this Helps.
Have a nice day,
mvincentc
what windows OS is it? 7, Vista, XP?
if the Lenovo screen comes up, then screen is good and is a problem with windows booting.
Try pressing F8 while it boots and boot windows into safe mode - there you can run a chkdsk /f from a command prompt and then reboot.
