First make sure your dvd drive is also a dvd burner, if it is not a burner then you can not write files to disks and will have to buy a new one
If that is not the problem, you have to make sure that you're using a dvd-rw (if the disc has info on it) or a dvd-r that has nothing on it. If you are not using one of those then the process will not work
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
Insert a disc into your computer's CD or DVD drive.
In the dialog box that appears, click Burn files to disc.
In the Burn a disc dialog box, type a name for your new disc.
Click Show formatting options, and then click one of the following formatting options:
Live File System
Mastered
Click Next to prepare the disc.
Now you can copy files to your disc using whichever method you selected.
you could use this burnaware its totally free if you dont like it just uninstall it also there are plenty of free burning sofware cnetdownload.com or majorgeeks
http://www.majorgeeks.com/BurnAware_Free_d5839.html http://www.majorgeeks.com/CDBurnerXP_d4242.html Active ISO Burner
will allow you to burn an ISO image file to CD-R, CD-RW, DVD-R, DVD+R, DVD+R
DL(Dual Layer), DVD-RW and DVD+RW (including double layer, DL). Active@ ISO
Burner software accepts command line parameters to automate ISO images burning
process. Burn audio, video,
and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is
the ideal choice for anyone looking for a simple but full featured CD/DVD
burner. Build and burn ISO files on the fly and compile all kinds of audio,
video, and data CDs and DVDs from any kind of file (MP3, WAV, AVI, MPEG, DIVX,
XVID). Instant CD & DVD Burner supports all major drives including CD-R,
CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB 1.0
and 2.0). Burn4Free CD and DVD
is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and
CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG,
FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to
disk, verify content, print compilations, copy DVD, copy BLU RAY and import
your audio compilation from M3U and ASX playlists. The drives supported include
dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R,
BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0). http://download.cnet.com/burnaware-free/3000-2646_4-10878661.html?tag=mncol;8 BurnAware Free is a
full-fledged disc burning tool - fast, lightweight, feature-packed and, most
importantly, 100% free. The program burns all types of CD, DVD and Blu-Ray
discs containing data, digital photos, music and video. With BurnAware Free,
you will be able to create bootable or multi session CDs and DVDs, high-quality
audio CDs from your collection of MP3, WAV, WMA, OGG, M4A, AAC and FLAC files,
burn disc images, copy discs to backup ISO images and do a whole lot more. Multi-disc file
backup and restore on CDs, DVDs and Blu-ray discs; create compressed backup
archives with powerful password protection; split archives automatically across
multiple CDs, DVDs or Blu-ray discs; restore archive contents to their original
locations; integrated Audio CD ripper store your audio tracks as WMA or WAV
files; new option for setting the number of copies you want to burn (available
for all disc formats); discs can now be verified immediately without being
ejected first (if the drive supports this feature); numerous other small
improvements that make the program easier to use and more effective; burn files
and folders on data CDs/DVDs/Blu-ray discs; burn Audio CDs from WAV, MP3, FLAC,
WMA and Ogg Vorbis files; burn MP3-CDs from your MP3 files; burn Video DVD,
Video CD (VCD) or Super Video CD (S-VCD); create and burn CD/DVD/Blu-ray disc
images; burn speed and other options can all be set automatically. Macrium Reflect Free Edition. An
award winning disk imaging solution for free. A complete disaster recovery
solution for your home and office. Protect your personal documents, photos,
music and e-mails. Upgrade your hard disk or try new operating systems in the
safe knowledge that everything is securely saved in an easily recovered backup
file. Macrium Reflect supports backup to local, network and USB drives as well
as burning to all DVD formats. This version is for non-commercial home use.
BurnAware Free is one of the most popular free
CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and
DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
http://download.cnet.com/Macrium-Reflect-Free/3000-2242_4-10845728.html
http://download.cnet.com/ImgBurn/3000-2646_4-10847481.html
ImgBurn is a lightweight
CD/DVD/HD-DVD/Blu-ray burning application that has several modes, each for
performing a different task: Read - read a disc to an image file; Build -
creates an image file from files on your computer or network (you also can
write the files directly to a disc); Write - write an image file to a disc;
Verify - ensure that a disc is 100% readable (you can also have ImgBurn compare
it against a given image file to ensure the actual data is correct); and
Discovery - used in combination with DVDInfoPro, you can check the quality of
the burns your drive is producing.
the disc.
Live File System
Mastered
