Kenmore Elite 44723SS Commercial Refrigerator Logo
Posted on Apr 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On the door display it says " ER DH " what does
mdscntst
Level 2:
Novelist:
  • Expert 130 Answers
  • Posted on Apr 13, 2011
mdscntst
Expert
Level 2:
Novelist:
Answers
130
Questions
0
Helped
60259
Points
367
I found this to be quite up your alley... gives you possibilities for DIY repair.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Cheats sf
We don't understand what you exactly mean. If it means a eror code, please find below the error codes and its solutions.
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error Er-Ff- Freezer fan fault. Write again if you're not satisfied with this answer.Thanks.
1helpful
Message ER DH continues to pop up on the door. If
ER =ambient temp sensor failure
DH= defrost heater
Defrost heater, temperature fuse short
circuit, unplugged connector(indicated
4 hour later after trouble)
You is gonna have defrost problemas!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Have a LG 3 door bottom freezer with error code Er dH. Was told by tech support to unplug for 10 mins. If this fails unit needs service. Is this correct?
dh means defrost problem.replace defrost control and element,behind freezer panel.dont forget to unplug fridge before you work on it
The panel control going shows Er in temp display
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
1helpful
Door display shows ER WITH A UPSIDE DOWN HP. I turn the power off and back on and the display goes back to normal but after several hours it goes back to where the only thing on the display is the ER PH...
That stands for "error defrost heater"
Even though the refrigerator has gone through a defrost cycle, if a temp sensor does not reach a set temp within an hour, that error will display. You may have a bad defrost heater, defrost relay, thermal fuse, blocked defrost drain,..... something wrong with the defrost system anyway.
1helpful
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
1helpful
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Error Code
dh error code is a defrost problem. You will need to call a qualified LG technician to diagnose and repair this problem.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
