20 Most Recent LG LFX25960ST Stainless Steel French Door Refrigerator Questions & Answers
I just had the same thing happen yesterday. The Sears repairman has been and gone, and he has advised me that LG has issued a Service Alert for the problem. They have created a new panel for the fridges with a thermostat that measures the temperature of the lights and shuts them off if they get too hot. In addition, he is going to replace the motherboard of the computer in the fridge. I feel that LG should send notifications to retailers that sell this product and that every purchaser of these fridges made in 2006 should be alerted to this potential problem.
LG LFX25960ST... | Answered on Mar 16, 2018
when half of the display goes out, it is giving you an error code telling you what is wrong with the fridge.Unplugging it simply resets the computer until the error comes back typically within a few hours.
without knowing what is lit up, it is difficult to help you so I would recommend putting the error code "which bars are lit up" in a comment so we can diagnose further
LG LFX25960ST... | Answered on Feb 03, 2018
it is not a great idea turning a fridge off and back on straight away. It will overload the compressor and cause it to trip out. I would suggest that the starter relay has failed on the compressor but if the fridge has been left to cycle on and off too many times, it will damage the compressor. Turn it off and get a fridge tech to look at it and confirm the fault.
LG LFX25960ST... | Answered on Jan 28, 2018
The control board has relays on it that are not user replaceable unless you can solder. You also must be able to find them since they are integral to the control board. I have attached the board info to this post. I would change the door switch before I changed the control board. http://www.appliancepartspros.com/lg-main-electronic-control-ebr34917104-ap4450216.html
LG LFX25960ST... | Answered on Nov 27, 2017
Hi!
Please check the "Troubleshooting" part of the manual to a similar LG fridge
https://manualsbrain.com/en/manuals/942858/?page=37
LG LFX25960ST... | Answered on Oct 24, 2017
sounds like when you moved it you created an air lock, when moving fridges etc. should always leave for 24 hrs to settle before plugging in.... , no guarantee but try laying it down and leaving overnight then stand it up again and leave for at least 24 hrs for the refrigerant to try and sort itself out. UNPLUGGED from mains of course... good luck
LG LFX25960ST... | Answered on May 02, 2017
Your ice maker freezer fan may be iced up. Take the freezer bin out and look at the back of the freezer. If there is ice built up, you have to defrost it.
LG LFX25960ST... | Answered on Apr 18, 2017
https://lgtechassist.com/kms/index.php?View=entry&EntryID=6937
You may have to have a tech look at these voltages and get the correct Main PCB or Freezer Fan Motor for this unit. Awhile back, LG had a problem with "icing-up" in the freezer around the fan blade. They came up with a different Main PCB which lengthened the defrost cycle and adjusted the freezer fan cycling times.
LG LFX25960ST... | Answered on Apr 03, 2017
ff is fresh food may be the ff thermisor but i would first check the freezer back wall is it frosted up can you hear the fan in the freezer blowing the air up to the ff section
LG LFX25960ST... | Answered on Dec 20, 2016
http://c.searspartsdirect.com/lis_png/PLDM/F1107036-00005.png
405A
on diagram Motor,dcPART NUMBER: EAU59551201 $27.41
Back ordered Call Marcone appliance ... Or goto searsparts
but this is the part you need.... To access it take outer door appart
see diagram on searsparts.com
LG LFX25960ST... | Answered on Apr 27, 2016
Hi Jerry
I found this with my coffee maker.
There was no sensor
It was based on time
Pull filter out & put it back in
Good luck
LG LFX25960ST... | Answered on Mar 14, 2016
ice tray heater is not working due to bad icemaker timer. thanks .
LG LFX25960ST... | Answered on Mar 05, 2016
check for broken springs. thanks .
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
525 questions posted
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
water ice not working
  • Refrigerators
