The service light remains on and the washing will not start.
Hi, make sure there's water in tap that feed machine, if there's, lock off you water, remove hose where it's connected to machine. valve on machine where you remove hoses from, check inside you will see strainer, clean any debris that's there, could be blockage of water entering machine, washer will start only when there's water in it. if it were clog up and you clean it, then connect hoses back to machine, and try it. if that didn't work, then you will need to check, water solenoid valve, that's the same valve, your two water hoses connected to, sometimes they burnt out, especially when there's low water pressure in tap, you didn't say what type of washer you got, top loader or front loader, if you got a top loader, fill it manually(bucket) and it will start, if water solenoid valve burnt out, if you got a front loader, you won't be able to fill it manually, if these tips didn't work, you will have to call mechanic, to make other checks. good luck
