20 Most Recent Kenmore 24622 Top Load Washer Questions & Answers
0answers
0answers
0answers
Everything works but the agitator
The small plastic pieces that are located under the agitator center cap that grip the agitator and turn it during the wash cycle are worn out. They are called agitator dog ears or clutch dogs. They must be replaced.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser, if there's any, by pulling it off the agitator top. cf99d03.gif
  3. If no dispenser is installed, insert a flat screwdriver between the agitator and agitator cap. Pry the cap off the agitator then remove the upper part of the agitator. cae2ce0.gif
  5. Use a socket wrench with extension or nut driver to remove the stud and seal holding the agitator to the shaft. 96cc7e9.gif
  7. Turn the agitator mover over on your palm. The cam and agitator dogs will come out on your palm. Pay attention to how the agitator dogs are installed. Remove the worn agitator dogs and install the new ones. c8eb889.gif
  8. If the agitator dogs are not worn, check the agitator shaft. Remove the round rubber seal off the top of the agitator and remove the agitator by lifting it straight up. Call up service if the shaft is worn. ca89530.jpged86a35.jpg
  9. Reinstall the agitator. Rotate it until the grooves on the agitator matches the grooves on the shaft then push the agitator down.
  10. Place the round rubber seal in the groove on the top of the agitator. 5314b95.gif
  11. Turn the agitator mover over and carefully insert the cam and agitator dogs up into the agitator mover until it stops. c55998d.gif
  12. Carefully turn the agitator mover over in upright position.
  13. Place the agitator mover with the cam and dogs over the agitator, lining up the tabs. The cam has a cut-out and tabs across from each other. The agitator has tabs across from each other. All of these must line up in order for the cam to slide down on the agitator.5f7e245.gif
  14. Push the cam down until the tabs snap together.
  15. Put the upper part of the agitator back.
  16. Using a socket wrench with extension or nut driver, insert the stud and seal through the agitator into the shaft and tighten it.
  17. Push the barrier cap and seal down into the agitator mover all the way. Make sure the round gasket is in the groove in the barrier cap. The barrier cap must be pushed down past the holes on the mover to allow the liquid from the dispenser to flow.
  18. Press down on the fabric softener dispenser or cap until it is all the way down on the agitator.
11/21/2013 9:21:27 PM • Kenmore 24622... • Answered on Nov 21, 2013
I cant remove the cap of my agitator in my
If the cap (or what appears to you to be a cap) cannot be easily removed then it may not be a cap at all. However, that said there is nothing to stop you using a good size flat blade screwdriver or cold chisel to try and GENTLY prise it off. If it doesn't give easily then it must be a cosmetic cap.Have you tried twisting the cap clockwise and anticlockwise to see if it is screwed on?Failing this, contact the manufacturer for more information. Poppa http://www.cdbaby.com/cd/poppamadison
10/3/2013 12:31:39 AM • Kenmore 24622... • Answered on Oct 03, 2013
I am down to the attachment with the 4 s
It will pull straight up with a rope or a belt underneath the agitator.
11/9/2012 3:13:13 AM • Kenmore 24622... • Answered on Nov 09, 2012
How to access the motor
A sledgehammer is the preffered method when dealing with a Kenmore.
3/20/2011 5:48:45 PM • Kenmore 24622... • Answered on Mar 20, 2011
Kenmore washer model 111 24622300 fills with water
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
3/19/2011 9:24:35 AM • Kenmore 24622... • Answered on Mar 19, 2011
Washer throws itself out of balance and stops
simply disconnect it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9/10/2010 4:26:11 AM • Kenmore 24622... • Answered on Sep 10, 2010
Agitator doesnot move, water will
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Two possibilities:
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If this is a basic top load, direct drive washer, luckily most mechanical parts are relatively easy to access and fix or replace. I'd hold off looking for a new washer until I checked the Lid Switch and Coupler. These are the two parts that tend to break on top load washers.
8/22/2010 6:53:10 PM • Kenmore 24622... • Answered on Aug 22, 2010
Timer/control knob on front panel has come loose
Next, see the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=fcfcd31a8e8aeeccda85d0c7abd587ba
NOTE:
Some Kenmore washers don't have removable end caps with screws underneath. These models usually have a spring clip mounted under where the end caps would be. In that case, use a thin putty knife to slip under the ends of the console to release the clips.
Also see the following Whirlpool / Kenmore Service manual for top load, direct drive washers. It details the two types of timers and how to access them.
7/29/2010 8:40:03 PM • Kenmore 24622... • Answered on Jul 29, 2010
The washer fills with water but does not agitate
Two possibilities:
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Second:
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
3/28/2010 6:24:29 PM • Kenmore 24622... • Answered on Mar 28, 2010
GE Top Load Heavy Duty Washer only works for small loads
Sounds like you need a new drive belt.
1/2/2010 4:36:52 AM • Kenmore 24622... • Answered on Jan 02, 2010
Kenmore 24622 Top Load Washer Logo
36 questions posted
Alexander
vince
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
remove agitator from ge mod wwse3160aoww
  • Washing Machines
