Once you get your Ford to start, does the engine run normally ? If yes, then timing not an issue. If no, you may consider timing, but not until other components have been checked.
Have you done any maintenance to your vehicle like a tune up, air filter / fuel filter change. Have you checked fuel pressure ?
Have you checked for any codes in the engine control module ?
SOURCE: Fuel Pump Relay
Obviously, you can jump the relay but it is dangerous on an extended basis. You'd have pressure in the lines when you don't want it there. Replace the relay if it is defective.
If you have other issues, you can check the pump back to the tank by going on the business end of the relay and looking for resistance at the pump to ground. If it is open, the pump or the harness is bad...GMs have harness issues...not Fords.
SOURCE: Could it be my fuel pump?
A fuel pump is not the problem, they either work or not, u are most likely having a loose of ignition spark, possible ignition module.
