Toshiba Satellite 1135-S1553 Notebook Logo
Posted on Mar 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shuts off by itself - Toshiba Satellite 1135-S1553 Notebook
Paul Bade
Level 3:
  • Toshiba Master 1,818 Answers
  • Posted on Mar 08, 2011
Paul Bade
Toshiba Master
Level 3:
Answers
1818
Questions
Helped
574942
Points
5816
Check the fan to make sure it isn't clogged with dust bunnies or malfunctioning. There's a solid-state thermostat that turns off the computer if the processor overheats.
I have a mitsubishi 73inch and it's blinking green & shut off by itself
Several problems may cause your Mitsubishi television to shut off by itself. ... Plug the television in, replace the fuse or reset the circuit breaker as needed. If the light is blinking green, a power surge or unusual digital signal was detected by the television. To prevent damage, the television shut itself off.
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 • Dryers
GE oven only heats up to 300 then shuts off
just a thought but maby the
tempature sensure has gone bad
1helpful
2answers
Tv shuts itself off
The power supply may be going on to protection mode. This is usualy because one of the scan amplifiers may have failed, or something is taking too much current and forcing the power supply to shut down.
Jerry G.
Dell Inspiron 1100 shuts itself off right after powering it on
if i take out the ram it does not shut off it is a problem with the ram
TV shuts itself off after a few minutes. Will also shut itself off if the DVD open/close button is pushed. Not sure if a DVD is in the machine or not. Any ideas??
I know that shortly after I purchased this tv mine also shut itself off occasionally. The owners manual says that if it is on dvd mode and it's paused or on an inactive menu or something for 15 minutes or so that it would shut itself off. If a dvd is stuck inside it may be causing this? I have no idea about the open/close malfunction.
Dehumidifier keeps shutting itself off.
For some reason it is overheating and shutting itself off. There is a law that all electronics are supposed to have a point to where it automatically shuts off if it gets too hot from a malfunction or loose connection in the circuit board. It is to protect the consumer. You either need to take it to a tech or get rid of it. Get a new one.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
