20 Most Recent Toshiba Satellite 1135-S1553 Notebook Questions & Answers
sounds like you didnt plug all of the cables back in. take the machine apart again and look to see if you missed anything
Toshiba... | Answered on Oct 04, 2017
It may be limited to the mother board speed or the bios is now incorrect if you have changed the uProcessor for a different speed/type.
Check with Toshiba to see if it is compatible.
Toshiba... | Answered on Dec 02, 2013
Mine did the same thing. I was told the hard drive crashed
Toshiba... | Answered on Aug 09, 2012
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope it helps you
Toshiba... | Answered on Mar 05, 2012
You said you connected your laptop to another monitor and nothing shows up - looks like a problem with graphics card/motherboard.
Toshiba... | Answered on Dec 19, 2011
If you connect a monitor to the video port on your Toshiba, power up the monitor first and then boot up the Toshiba then the video will automatically divert to the monitor.
Toshiba... | Answered on Jun 06, 2011
Check the fan to make sure it isn't clogged with dust bunnies or malfunctioning. There's a solid-state thermostat that turns off the computer if the processor overheats.
Toshiba... | Answered on Mar 08, 2011
There is a way to correct this but not without a windows disc.You can contact your system manufacturer for a copy of the disc, but they will most likely charge you. Also you can borrow a disc from a friend so long as it is what you are licensed for ie Windows XP, Windows Vista, Windows 7 home or pro. Also you can torrent a disc but I cannot advise as to its legality.
Toshiba... | Answered on Feb 28, 2011
depends whether you have an old disk-type drive thats inside the machine.newer systems and future technology dictate SSD's these days(Solid state drives) They have no moving parts and are a series of chips,.processors and minature surface mount components non-user servicable but replaceable.
Toshiba... | Answered on Sep 06, 2010
remove CMOS battery and wait for 5 minutes check it your bios pawd is no longer available
Toshiba... | Answered on May 06, 2010
Hi
Thank you for your query
Please try the folowing
1) Switch on the Laptop
2) Press the F12, or del key to enter bios/setup
3) Leave it in this mode
4) If the laptop switches off, then your CPU is overheating and the heat sink will need to be replaced
Please book your laptop into a reputable PC shop for repair
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Toshiba... | Answered on Feb 22, 2010
Download the drivermax software from www.drivermax.com this software is free and will autodetect and download any unknown computer devices
Toshiba... | Answered on Dec 11, 2009
did you have it in the past? is your wireless adapter turned on? toshibas have a tiny switch someplace on the side of case. and the fn key combo also will turn off. make sure wireless light is on. if it is than card may be bad, if not than turn it on.
Toshiba... | Answered on Dec 01, 2009
Try removing the battery and replacing it. If that doesn't fix it hold down the power button and it should re boot. If still a problem we can go further.Thanks
Toshiba... | Answered on Mar 02, 2009
Refer to toshiba's website and try to reinstall device drivers.
Toshiba... | Answered on Jan 26, 2009
Perhaps you have not installed ALL the drivers for your system.Sometimes a missing driver for other hardware causes a problem.After installing all the drivers for your system and if it still doesnt work , try using the connection manager built into windows (instead of configfree).
Toshiba... | Answered on Dec 18, 2008
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region.
There are several available on the Internet but my favourite is DVD-Region Free
www.dvdfab.com/products,free.htm
Toshiba... | Answered 3 days ago
Toshiba Satellite 1135-S1553 Notebook Logo
27 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba satellite 1135 s155 notebook
  • Computers & Internet
