This is classic fuel starvation, start by removing the fuel hose from the tank and replace the filter on the end, if no better, it may be a tank breather issue, when the saw starts to die slacken the fuel cap, if the saw picks up you need to replace the breather, if no better you can make a small adjustment to the H screw on the carb, unscrew ( counter clockwise ) the H screw this will richen the mixture, you will need to pull the anti tamper sleeves back on the screws, this can be done by gently screwing a suitable self tapping screw into the sleeve, when it hits the screw head under neath the sleeve will start to pull back, once pulled half way off you can enter a 2mm screw driver through the centre if the sleeve and intp the slot in the adjuster screw underneath.
