Refrigerators Logo
Posted on Feb 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice storm knocked out power for 3 days. When power was restored. no ice would discharge from ice maker into storage bin. I removed ice maker and poored boiling water over the frozen ice in tray. I emptied the tray and dried entire ice maker and reinstalled. The ice maker made ice and delivered the cubes to the bin. But after another 24 hours, the tray is full of ice but will not deliver cubes to the bin. I repeated this process two more times with the same results, one loan of ice in the bin and frozen ice in the tray that will not drop into the bin. What could be wrong? Nothing is broken or out of position. Please help?
Anonymous
Level 3:
  • Master 552 Answers
  • Posted on Feb 26, 2011
Anonymous
Master
Level 3:
Answers
552
Questions
0
Helped
536842
Points
1583
This video explains how to repair a kenmore ice maker
You can also post your question in the Kenmore Repair Forum
Kenmore Repair Articles
HOW TO REMOVE ICE MAKER STORAGE BIN ASSEMBLY IN FREEZER
empty freezer put a pot of boiling water under the ice bin and let it melt it
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
DC33 PA 1A
If the machines ice storage capacity is 26 lb per a day then that is all it will make in a 24 hr day Now this depends on water temp entering the machine, the ambient temperature around the machine and the condenser coil and fan is not dirty. Now the machine is capable of making 33 lb of ice in a 24 hour day but the storage bin capacity is only 26 lb if you don't remove any ice it will make only around 26 lb and shut off until it melts and causes the ice maker head to start.
2answers
Scotsman cme 1656 bill full stay on after cleaning
Ok did you damage the bin thermostat cap tube? The bin thermostat is what tells the unit the bin is full if so replace it.
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
1helpful
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
Sub zero particles in ice from ice maker
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1 Lift the power bar located above the ice maker storage tray.
  • Step 2 Unplug the refrigerator.
  • Step 3 Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
    Clean the Ice Machine
  • Step 1 Remove the ice machine storage tray.
  • Step 2 Dump any water in the ice machine storage tray.
  • Step 3 Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
  • Step 4 Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
    Reassemble the Ice Maker
  • Step 1 Replace the ice machine storage tray.
  • Step 2 Plug the refrigerator into the outlet to restore power.
  • Step 3 Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
  • 2helpful
    Ice maker not getting water after changing filter
    Check the following:
     Is the freezer door closed completely?
     Is the ice storage bin installed correctly?
     Is there ice in the storage bin?
     Has the ice frozen in the storage bin?
     Is ice stuck in the delivery chute?
     Has the wrong ice been added to the storage bin? Use only
    cubes produced by the current ice maker.
     Has the ice melted around the auger (metal spiral) in the
    ice bucket?
    Dump the ice cubes and clean the ice storage
    bin.
     Is the ice dispenser stalling while dispensing “crushed”
    ice?
    Change the ice button from “crushed” to “cubed.” If
    cubed ice dispenses correctly, depress the button for
    “crushed” ice and begin dispensing again.
     Has the dispenser arm been held in too long? Ice will stop
    dispensing when the arm is held in too long. Wait 3 minutes
    for dispenser motor to reset before using again.
    The ON/OFF switch is located on the top right side of the freezer
    compartment.
    To turn the ice maker on, slide the control to the ON (left) position.
    To manually turn the ice maker off, slide the control to the OFF
    (right) position.
    NOTE: Your ice maker has an automatic shutoff. The ice maker
    sensors will automatically stop ice production, but the control will
    remain in the ON (left) position
    REMEMBER:
     Allow 24 hours to produce the first batch of ice. Discard the
    first three batches of ice produced.
     The quality of your ice will be only as good as the quality of the
    water supplied to your ice maker. Avoid connecting the ice
    maker to a softened water supply. Water softener chemicals
    (such as salt) can damage parts of the ice maker and lead to
    poor quality ice. If a softened water supply cannot be avoided,
    make sure the water softener is operating properly and is well
    maintained
    The Dispenser Lock (on some models)
    Your dispenser can be turned off for easy cleaning or to prevent
    unintentional dispensing by small children and pets.
    NOTE: The lock feature does not shut off power to the product, to
    the ice maker, or to the dispenser light. It simply deactivates the
    dispenser levers. The ice and water dispensers will not work.
    Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
    UNLOCK button to unlock the dispenser.
    Style 2: Press and hold the LOCK OUT button to lock the
    dispenser. Press and hold the LOCK OUT button a second time to
    http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
    2helpful
    My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
    ice bucket?
    bin.
    ice?
    Ice maker leaks into the ice storage bin
    turn off the power to the appliance and apply a hairdryer to the ice maker compartment for about 2 mins , worked for me.
    Jan 11, 2008 • Freezers
    Top Kenmore Refrigerators Experts
    vince
    Johnny 1000
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
