The only thing I can say is make sure that vga cord is pluged in all the way. on the computer and monitor
plugged in.
or if the pins or wires inside are missing
making eDID comms. dead (sleep dead)
0x0D Interface Power Sequencing
if eDID is dead, the above fails
if that fails sleep fails.
so bad cables. or wrong monitor
if monitor is 2000 year made,oops.
no eDID. support.
https://en.wikipedia.org/wiki/DisplayID
and last of all , we know how far VGA RGB/sync can go with good cables, 40meter easy but not Edid.
eDID comms (read sleep mode) uses weak signling called I2C transmitters/receivers.
these signals do not go far,
but if done right (most are NOT)
A classic spec is 25 meters. 82feet,imperial.
the problem is 3 fold,
the VGA CARD receivers the cable type and the monitors receivers.(and noise)
what your system can to distance wise on I2C lines is not known. (but 26ft sure)
but there is cool program (application prog)
that lets you see if the eDID data is working
called
EDID Manager (editors ,scanners ,etc)
one simple and safe (virustotal, safe)
is this.https://nirsoft.net/utils/monitor_info_v...
this program is very good and PORTABLE,(no install needed , yah.
now run 2 times.
first whit the working cable short.
then with failing cables longer.
the data must be there or edid is dead.
if you scan it and see the line there.
in the report.
see words , there (modes supported)
standby _suspend and low power.
mine new monitor shows, no,no,yes.
now you have a tool that allows you to
know many things,
what modes work, and if the cable fails for edid,
now my acid test.
I have headless, server that I have no monitor at all and run remote software in to it. to do that I have dummy DVI/ plug installed.
the program above shows INACTIVE.
and all lines are dead.
if you hide inactive (in view)
so that is what you get ,with a:
1:DEAD OR MISSINg monitor
2:bad cable.
"Rather, I get a message that it cannot detect the VGA cord.)
if windows told you that, no version stated
but if yes, then that means the monitor ID is failing,
if the monitor OSD brain in the unstated monitor told you that error, usually in a black screen. (then in 10seconds self turns off, for screen protection)
no sync or signal?
no cables found? ,vga,dvi/dp/hdmi
or out of range.(mostly seen on relic monitors)
all of those means signals on the cable are wrong. (ANY)
also some video cards monitor the RGB video line drivers(phy) currents and if too high or low
shuts down the video card fast. (self preservation mode, as shorted cables do happen)
my Nivdia GTX650 does that. too.
then my driver for GTX tells windows that
and then windows tells you that.(windows pop up window)
Every tech that works with headless servers knows this and with KVM switches from H3LL.
vast KVM are edid DUMBB(sic).(fail hard)
and all users of projectors (OMG) oh my golly (gee).
in the old days, with CRT bulb monitors
one can burn up the phosphor screen if settings were wrong, SOME software still have protection for those relic monitors.
The PC scans the monitor to see
1:if it is there. (if not goes to low res mode or goes black screened. booted.)
2: what can it do. (all features supported)
3: and then shows you what valid resolutions you can use,
4: and to see what sleep modes are in fact supported, if none, then there will be NONE.
DDC goes back to the year 1995.
with over 8 revisions and
edid.2006.
SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
Recently, my desktop monitor goes into "power safe mode" as soon as the Windows XP logo appears after the POST on my Dell Precision 370. The computer continues to run. I was able to go into safe mode, and all the devices seemed to be active, especially the nVidia graphics driver. The video settings in the BIOS were also correct along with power management settings. I even tried different monitors. At this point, it seemed as though the graphics card might be faulty.
The last suspicion was the graphics driver, so I uninstalled the graphics driver in device manager: Control Panel > System > Hardware > Device Manager, and when I rebooted the computer, I was able to log into Windows normally. When I went to see check the status of the graphics driver in Device manager, I noticed it re-installed the same driver, but this time it installed correctly and I was able to access the nVidia graphics utility.
If the driver does not roll back or re-install automatically, just download the latest recommended or urgent video driver from Dell or whatever mfr while in safe mode w/ networking or on a flash drive, and install the driver in safe mode, reboot and hope for the best.
* If you have any specific or 3rd party display utilities, disable or uninstall the utility in the startup as they may be the cause.
SOURCE: Dark Screen Inspiron 9100
If you replaced the inverter board and its still dark you need and new backlight itself http://cgi.ebay.com/LCD-Backlight-Lamp-for-Dell-Inspiron-9100-15-4-WXGA_W0QQitemZ150217509448QQcmdZViewItem
SOURCE: Dell E173FP stuck in power save mode
Just had the same problem... what worked for me was simple. Unplug the cable from the monitor, hit the power button a few times until Dell screen poped up with a few color bars because it knew it was no longer connected to a PC. Then plugged the cable back in and all was fixed.
SOURCE: Dell C521 Where to connect monitor?
This means that you have an external video card (which is not outside the computer). This video card will be plugged into the motherboard. That message is saying that the port on the back of the computer that your monitor is plugged into is the wrong one. You need to look for another port on the back of the computer.
Here is a picture of a VGA port that you should use if you have a VGA cable to connect the monitor (Blue Ends).
http://news.softpedia.com/images/reviews/large/VGA.jpg
Here is a picture of a DVI port that you should use if you have a DVI cable to connect the monitor (White Ends).
http://zedomax.com/blog/wp-content/uploads/2008/09/dvi.jpg
So depending on the cable and connections that are available on your computer and your monitor depends on what you have to use. I hope that wasn't too confusing. Let me know if you need more info.
YES, vast times !!!
Hi bruce_freili, I want to help you with your question, but I need more information from you.
Can you please add details in the comment box?
We must guess sleep works with the normal cables (other shoe falls off foot; shock)
Dell Inspiron 560 (our only clue)! wow.
Desktop PC.
VGA (port/jack) but
is this the mainboard VGA jack or addin card PCI-express video card jack VGA?
if you do have both do both fail?
if using a CARD there what is it? name/model.
NO OS stated windows? what version??? XP?
No cable maker stated,
no distance stated or why so far.
no monitor make and model stated.(wow important)
first off cheap cables only go 15feet then go blurry or worse.
or have all those sleep in pins missing.
posting this complex topic (sleep is)
and not all the details makes an easy answer impossible (yah)
The modern PC and monitor (if they both are)
uses eDID communications pins /wires to
enter sleep mode. if any of the many pins are missing, sleep fails.
so based on almost no facts at all
I call , cheap cables.
here are some that work up. (but distance matter)
to go far , with good cables
they have spec. on top brands
the best cable is double Shielded and Sleep mode certified (no missing pins)
and your resolution setting limit this range.
if you go to far with cable a VGA buffer box works, as seen in projection theaters.
see the word FULLY here, full pin support
like most things in life, cheap never gets
you quality, and the below cable is one example of many top preforming cables.
DDC2/E-DDC Data Support (for monitor detection by OS)
https://www.amazon.com/MyCableMart-Premi...
