20 Most Recent
Dell Inspiron 560 Desktop Computer (Intel Pentium Dual Core Intel Pentium Dual Core E5700 1000GB/6GB... (DDPDAT215) Questions & Answers
When i plug my tv
sometimes new a Video Driver and DirectX can solve this problem.
so download these drivers from here:
http://downloads.guru3d.com/GeForce-Forceware-260.99-Win-7-'-Vista-64-bit-download-2634.html#download
http://www.softwarepatch.com/windows/directx.html
Navigation to the webpage was canceled
This is a Security Message. It is letting you know that your ISP has prevented access to the website because the website has been classed as dangerous by your ISP.
RESET PASSWORD
Click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password.
In New password and Confirm new password, type the new password, and then click OK. Notes:
You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer.
You cannot change your network logon password in User Accounts.
To change your own password, press CTRL ALT DELETE and then click Change Password also if you want set a BIOS password
Restart your computer during the boot up process you will see on the screen for a short amount of time to press a certain key to enter set up usually the Delete or F2 Press and hold that key during the boot up process to enter BIOS
Using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there.
Click start control panel user accounts on the users tab
Click the name of the computer administrator you can change the password there.
You should make a note of any passwords and keep them separate to your computer incase of memory lapses.Hope this helps
When I power my desktop
When you first power on the computer tap the key. If you get the boot menu then more then likely you have a video software driver issue when your computer tries to load the operating system. Only recourse is to fix the conflict or reload OS ( operating system).
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
How to delete bookmarks
google dead ?
first off my PC has 4 browsers.
all 4 different answer.
IE11 ( or OMG 1 to 10 )
Edge
Chrome.
Firfox v95 (click tab book marks then click manage BM, the right click any or all you see and delete.
learn google
like
google IE11 bookmarks delete.
and read, millions of hits world wide all true.
Fix Heating issues with dell laptop
Tips to fix heating issues in Dell Laptops:
Inspect and clean the air vents and fans
Restart the computer
Update the BIOS and Chipset driver
Download and install Microsoft Windows updates
Run a hardware diagnostic test
Use Dell Power Manager to manage thermal performance (applicable for select Dell laptops)
Improve efficiency to reduce heat
Perform a Windows System Restore
Restore the computer to factory defaults
I want to delete my shtyle.fm account plz help me to delete acoount permanently
I don't know its solved or not but here's the method. Step 1 : Login to your profile of shtyle.fm Step 2 : Move your cursor to the "you option "or "your profile option". Step 3 : There, You will see the link of "Account Settings". Step 4 : Click on that link and you will see "Delete profiles and friends" Option There. Click on it. Step 5 : After that you will see the information that why you should't delete the account and bla bla bla. Step 6 : Just click on the continue button. I highlighted the link in below given image. Click there. Step 7 : Now you will see the box where you can enter the reason why you want to delete your shtyle account and profile. Enter reason or leave it blank and click on delete option. That's It. Your account is deleted. When you try to login with the same credential again you will see this. If you see below given error then your account or profile is deleted.
Source : Youshouldlisten.com
