Canonical Ltd. Ubuntu Logo
Anonymous Posted on Jul 27, 2008
Install a printer on Ubuntu
How do i install a printer on Ubuntu?
  • 3 more comments
  • Anonymous Nov 05, 2008
    I have the same problem. The real problem is, that the ubuntu printer installer does only list some very old printers. All-in-ones are too modern for linux.
  • jealea Apr 21, 2009
    I find it impossible to instal a printer. Also impossible to uninstal Ubuntu. Wish I could get back to Windows.
    I find it impossible to instal a printer. Also impossibleto uninstal Ubuntu. Wiah I could get back to Windos.
  • Anonymous May 24, 2009
    It depends on your printer type and lexmark does not support ppd files any more
  • Marjorie Smith
    Marjorie Smith Nov 29, 2013
    I have followed the steps below many times. they DO NOT WORK!
Anonymous
Level 2:
  • Expert 32 Answers
  • Posted on Jul 27, 2008
Anonymous
Expert
Level 2:
Answers
32
Questions
29
Helped
148306
Points
153
Hi Josh,
It's pretty easy to install a printer on Ubuntu, just follow these simple steps.
-Open System > Administration > Printing
-The Printers window is now displayed. Double click the New Printer icon.
-Now displayed is the Add a Printer window. Select Printer Type as Local or Detected Printer.
-Click on Use a detected Printer, select a printer from the list and click Forward.
-Select the Manufacturer, Model and Driver. Click Forward.
-Choose a name that will help you remember the printer & it's location.
-Click Apply.
Congratulations you added the printer to Ubuntu.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 01, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
11929
Points
19
- Back on Nov 5, 2008 user carracho commented:
"...All-in-ones are too modern for linux."
The problem is not one of linux printer support being "modern".
The issue is that certain printer manufacturers have agreements with Microsoft (or from some other unknown reason) to not release the code to control their machines into a medium whereby those writing linux drivers for printers may legally write a driver for said machine. Complain to the manufacturers for their use of proprietary codes or use of chip systems that actually are dependant on microsoft internal systems functions to operate.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11188
Points
Indeed,
-Open System > Administration > Printing or Systeem > Beheer > afdrukken (NL)
-Click Apply.
And my Samsung scx 4500W was printing over the network wifi. So this all-in-one of Samsung was no problem for Ubuntu!
2 Related Answers
Taufeeque Gadhawala
  • 51 Answers
  • Posted on Aug 03, 2010
SOURCE: Installing printer in Linux
Manually Installing a New Locally Connected Printer and Printer Driver When Ubuntu detects a printer it will automatically select a driver if the printer is recognized and a driver is available. To manually add a printer, begin by clicking on the New button in the Printer configuration toolbar. A Please Wait. Searching for Printers dialog will appear as the system is scanned for a locally attached printer. Once the search is complete, the New Printer Wizard dialog will appear including an entry for each detected printer. In the following figure, Ubuntu has detected an HP DeskJet printer connected to a USB port:
Select the desired locally connected printer from the list in the left hand panel and click the Forward button to select the appropriate printer driver. On the resulting screen select the printer manufacturer and choose the model from the list. Click on the Forward button to install the appropriate driver for the printer:
Once the printer driver matching the printer has been selected, click the Forward button and enter the optional printer description and location information. You should be returned to the Printers dialog where your new printer should be listed.
Once the driver is installed you are ready to try out the printer. In the Printers dialog select your printer, right click with the mouse to pop up the menu and select Properties. Click on Print Test Page to send a test page to the printer.
Anonymous
  • 32 Answers
  • Posted on Jul 28, 2008
SOURCE: Ubuntu printer install
Checking if a Printer is installed on Ubuntu.
Go to the Printers window (System > Administration > Printing), if you find the printer you are looking for, it's installed.
If you can't find your printer, i answered a question on how to install a printer on Ubuntu earlier, check it out.
Please rate my solution,
Thank you.
How Do I Install Epson Printer Driver on Ubuntu?
To install Epson printer driver on Ubuntu, you can follow these steps:
  1. Open the terminal on your Ubuntu system by pressing Ctrl + Alt + T.
  2. Run the following command to update the list of available packages:
sql
sudo apt-get update
  1. Install the required packages for Epson printer drivers using the following command:
csharp
sudo apt-get install printer-driver-escpr
  1. Connect your Epson printer to your Ubuntu system using a USB cable or connect it to your network.
  2. Go to the Printers settings by searching for "Printers" in the Activities menu or by navigating to Settings > Devices > Printers.
  3. Click on the "Add" button to add your Epson printer.
  4. Select your printer from the list of available printers and click on the "Forward" button.
  5. Ubuntu will detect the drivers for your Epson printer and install them automatically.
  6. Follow the prompts to complete the installation.
Once the installation is complete, you should be able to print from your Epson printer on Ubuntu.
1helpful
I use ubuntu 12.04 and i wand to install my printer samsung SCX-4521F. What do i have to do?
sir i am using ubuntu 12.04 i need to install samsung printer drivers
model num is scx-4521fs
2answers
How can i install a printer to an ubuntu os
1.) Ubuntu - Printers
https://help.ubuntu.com/community/Printers
2.) How do I install my printer with Ubuntu?
http://askubuntu.com/questions/93637/how-do-i-install-my-printer-with-ubuntu
I got an HP printer and I need to know how to install it with ubuntu
You can easily install it with the Hewlett-Packard's Linux Imaging and Printing software (HPLIP). HPLIP is a tool that can easily be installed to add any printer HP has to offer depends on your ubuntu build. here is a tutorial to install any HP printer.
http://hplipopensource.com/hplip-web/index.html
this is a tool to find your model and see if it supported
http://hplipopensource.com/hplip-web/supported_devices/index.html
Ubuntu forums has a little help to offer for desk-jets don't let them confuse you read first and see if the problem is resolved. then type in the commands to install from what they offer.
PS ubuntu forums requires a membership to see their info its a good thing to get...
Good Luck
Osogama
1helpful
I am using ubuntu 10.04.2 and epson lx 300+ printer. When i try to install i am not able to select device as parallel port #1. What should I do?
I don't know I've used Ubuntu for years and I've never had to configure a printer in my life, it allways managed to install it self...
Is your computer connected to the internet when Ubuntu install the driver???
Have you tried an other printer cable??? have you tried the printer in an other computer???
1helpful
Cant install lex 1420 drivers on jaunty UBUNTU
have you tried going to system,printing click on new and let it search for printer?
1helpful
Brother DCP-165 Printer install
go to brother's website and download the specific CUPS package for your ubuntu release. You need to download and install cups wrapper and lpr driver. Click below for the download links:
cupswrapper: HERE
lpr: HERE
2answers
hi sir
I can easily understand it. just u see taskbar at the right corner of ur computer monitor. if not installed, u cann't see anything like a icon of printer.
Top Canonical Ltd. Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
