To see which color is having an issue, go to printer control panel and select "settings" > Tools> Print report> Print Quality report. When the page prints out, you will see which color is the problem. After you have figured that out, make sure the problem is not with the cartridge.
If you see lines or missing colors, clean the printhead by removing it from printer(open cover, lift gray latch on the right side of the cartridges, remove cartridges and the printhead will easily slip out by pulling up)
then soak the printhead in half inch deep amount of window cleaning solution. Preferably warm. Let soak at least 3 hours. Dry out the printhead and wipe rear conacts from moisture and dirt. Reinstall into printer and see the results.
-Alex
303Electronics eBay Stores http://www.303electronics.com/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
SOURCE: Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
SOURCE: how to load 5x7 photo paper into hp photosmart D7460 ??
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
SOURCE: hp 9130 printing blue stripes on photos...
On the control panel, press MENU.
Press (up) or (down) to move to the item you want, and then press (select).
Go to maintainance.
Press - or + to select the value that you want, and then press (select) to save the setting.
If there is no - or + around the setting, the setting cannot be changed.
on the maintainance tab is,
clean heads, align, calibrate, etc..
Hope this helps
Regards.
SOURCE: HP Photosmart C6380 says scan from computer?
This means you should open the HP software, whatever your version is called, and start the scan from your desktop instead of pushing buttons on the printer console.
Go to Start>All Programs>HP Solution Center.
See also articles here.
If you don't have the HP software installed, and you're using vista, see here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: photosmart c6380 printing green only on photo
i had a similar problem on my canon try changing ink colour cartriges
