Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit Logo
Posted on Feb 17, 2011
H50TR13 IC:1640B-TR04 - Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit
Looking for a users manual?
I went to B&D and followed links to the parts & manuals for this toaster oven and received this message, "There are no parts or manuals for this model number: TO 1640B. They did have a picture of it.
I have a bulldog H50TR13 1640B-TR04 remote which has stopped working. Playing with battery putting in and outmay get it to work for a short time but then goes dead,
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic o r fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
2answers
Removal of apron and feed mechanism
I have worked on similar machines so I hope this helps. At the tailstock side, there is a bearing block that supports the leadscrew etc. Remove any taper pins and bolts that hold the block in possition. Now the shafts should only be supported by the headstock and apron. Turn the apron away from the headstock (using the feed handle). The shafts are usually keyed on splined into the head (dont force it). Once the shafts pull free from the head you can turn the leadscrew out by hand and slide out the power shaft etc. The apron should then either be able to roll off the tailstock end (remove any stoppers) or be lifted upwards (remove any guides or stoppers).
Victor lathe 1860 dcl
may be heavy load is drawing exess currant
Top Toyota Vehicle Parts & Accessories Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
