20 Most Recent Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Questions & Answers
Just installed one. was
i have a chipper and it started giving lot of problems 4 yrs ago, so I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
1/23/2019 9:09:25 AM • Bulldog Remote... • Answered on Jan 23, 2019
My 2002 Chevy S-10 security light stays on not flashing when key is on/won't start
replace the starter switch or key switch
4/19/2014 2:17:44 AM • Bulldog Remote... • Answered on Apr 19, 2014
The security light was on in my Chevy Impala, so I
Have you tried resetting the computer?
10/23/2013 6:49:04 PM • Bulldog Remote... • Answered on Oct 23, 2013
New battery and alternator on 1995 3/4 ton fleet truck won't hold charge for more than a few days
Mark, have you checked your battery cells for water,if you can, open each cell on top of battery,look inside and water level should be up to bottom of opening just above the plates inside..if water is low in each cell then you have to fill each cell that is down ,DO NOT FILL TO TOP OF CELL OPENING. EACH CELL should take a little water only,, also have you had your alternator tested, new ones can be faulty, have you checked your ground wire from the battery, sometimes the connection is corroded or paint underneath the bolt, rmove gound and sand end with emery cloth or sandpaper, then sand area where connection is and sand with sandpaper,connect back to place you removed it from,make sure bolt is tight, after you do this, start truck, check the votage of battery,by using a volt meter, put one probe on red terminal and one on black terminal,see what the meter is reading, should be reading about 14-15 volts.. if not then your battery may be defective,.. try another battery that you know is good.. also is you drive belt on alternator and pulleys tight,try and tighten it by loosing the 2 bolts on alternator, one bolt is long near top and the other bolt is short, just loosen them enough to move alternator up to tighten ,when belt is tight tighten the bolts up. check tightness on belt by pushing down on belt, if you push down and move more than 1/2 inch, then you have to tighten again..
10/4/2012 1:41:35 PM • Bulldog Remote... • Answered on Oct 04, 2012
I have a bulldog fcc id:h50tr13 ic:1640b-tr04
if it's the lcd screen, it can be fixed for $25 us
7/27/2012 4:40:29 AM • Bulldog Remote... • Answered on Jul 27, 2012
93 chevy truck runs then when warm it stall and wont start till its cool
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
3/3/2012 11:09:36 PM • Bulldog Remote... • Answered on Mar 03, 2012
No range for my Bulldog Remote Start.
Get a Viper 5900, it has a 1 mile + range
Or a viper 5601 has a 2000 ft range.
Bulldog is DIY and entry level stuff. You cant expect much from them.
The wire antennas work the best when they are stretched out. Not wadded in a ball or in a loop. If you have to loop it use figure 8's. Try streatching it up the "A" pillar and in the headliner across the top of the windshield. Also, do not ground the antenna, and let the end hang.
Also check your hot and ground connections. Make your ground at the kick panel sheet metal. Do not use a factory ground or a metal bracket in the dashboard. Do use a file or sandpaper to buff the ground site to the bare metal.
Guy
2/7/2012 3:53:47 AM • Bulldog Remote... • Answered on Feb 07, 2012
Need help finding a diagram
All data , mitchell, shopkey, you can paid by day!
2/4/2011 3:05:05 PM • Bulldog Remote... • Answered on Feb 04, 2011
Have model #RS82 installed it on a 2001 Dodge
Did you install the hood pin switch? If so, does the blower and dash lights come on when you press the start button on your remote? I have one installed on my 2005 and it works great. I did not install the hood pin switch ( Not the best idea if you take the vehicle to a mechanic for engine repair.) But I shorted the wire as if the hood were closed all the time.
12/21/2010 12:54:18 AM • Bulldog Remote... • Answered on Dec 21, 2010
Remote starter doesn't function
if the battery was replaced or any terminals removed, you may have lost the tach programming for the remote starter. Goto http://www.bulldogsecurity.com/bdnew/installmanuals.asp and look for the remote start unit you have in the manuals and it will tell ya how to reprogram the tach memory.
7/4/2010 9:05:16 PM • Bulldog Remote... • Answered on Jul 04, 2010
Must push start, then wait and push start a second
check under the dash for a small toggle switch, somw have a red rubber cover on them, once you find the switch flip it off
3/27/2010 3:34:16 AM • Bulldog Remote... • Answered on Mar 27, 2010
Hi i wired up the bulldog remote vehicle starter
Does your remote starter work now
3/6/2010 3:18:03 AM • Bulldog Remote... • Answered on Mar 06, 2010
My remote starter is not responding. The antenna
press the "f" button 2 times then the lock button, if this doesn't work and you know how to open the remote under the battery there is a small screw take it out and open the case, the top circuit board comes off, pull straight up on it, turn it over and check the 47.025 Mhz crystal there are 2 wires going into it they may need to be resoldered or you can mail it in to them with $25 they will fix or replace it
3/6/2010 3:13:04 AM • Bulldog Remote... • Answered on Mar 06, 2010
2answers
Bulldog Remote Starter On 92 Blazer-Cranks but no fuel pump
I've wired several of these and you have likely hooked up the wires wrong its not giving power to the right wires at the bottom of your steering column...........re check your connections
on your truck there are 3 wires that need power for the starter to work they are the orange,pink and brown
hope this helps!
2/28/2010 7:55:47 PM • Bulldog Remote... • Answered on Feb 28, 2010
VEH STARTS WITH REMOTE THEN SHUTS RIGHT BACK OFF
what is the year make and model
2/24/2010 4:41:56 PM • Bulldog Remote... • Answered on Feb 24, 2010
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
Popular Tags
85 questions posted
Top Bulldog Security Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
John
John
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Bulldog Security Vehicle Parts & Accessories
Most Popular Question
2002 chevy s 10 security light stays not
  • Vehicle Parts & Accessories
