HP Photosmart C4580 All-in-One InkJet Printer Logo
Anonymous Posted on Jan 29, 2011
I accidentally uninstalled my HP Photosmart C4580 Printer and do not have the originally software disk to reinstall it. Is there any way I can reinstall without the disk?
Anonymous
Level 3:
Brigadier General:
  • Master 7,191 Answers
  • Posted on Jan 29, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
7191
Questions
Helped
1334904
Points
22939
You can download the installation driver and software from manufacturer's support website by clicking this link
On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu and click the "Next" button.
The list of available drivers will load only after selecting the operating system of the computer.
Then download the "HP Photosmart Full Feature Software and Drivers" package.
Hope this solves your problem. Thanks for using FixYa
  • Anonymous Jan 29, 2011
    Kindly let me know the operating system of your computer so that I can provide you with the direct download link.
    Thanks.
2answers
2answers
When I try to scan from the two pc's that use the same HP 4500 photosmart on a wireless network I get an error mesage. Yet when I connect a laptop with the usb cable into the printer HP 4500 it scans...
Base from the description of your problem this is some kind of issue with the software , and according to you already tried uninstalling and reinstalling.
So if you have not done reinstalling using the software from HP site better reinstall the softwrae using that and check if that corrects the issue.
My printer won't print.
click start click on run or the keyboard shortcut is the windows key and the letter r at the same time
a run box appears click the browse button
click my computer and select the disk drive the software cd is in. look for a folder that is titled util or utility, open it and open the ccc folder. from there select uninstall l3
make sure your usb cable is disconnected
click okay to run the uninstall... it will begin to remove the hp software and drivers. let the pc restart, upon restart run a disk clean up
once the disk clean up is completed re try the install with the usb cable still disconnected untill the sw advises you to connect the device.
that should install the drivers cleanly and you should be able to print and scan
Windows installer and not find status.msi
Sometimes when you delete a program you have to restart your computer for it to uninstall. Then when you reinstall using your disc that came with the printer if anything remains it will ask if you want to replace or add click replace and finish the install by the prompts from the disc and printer should work.
2answers
HP C4580 PhotoSmart Install Crash
My photosmart all in one printer C4400 does not turn on. I have tested all connections. It still does not turn on.
2answers
Unable to print or scan with HP Photosmart 2575 to new Vista
That means that the printer software installation is corrupted.
You need to reinstall the drivers for this printer.
If you have original printer disk, use the disk to reinstall the printer.
If you have misplaced the disk, then you can download driver from link below:
HP Photosmart 2575 All-in-One Printer
Run installer file after download has finished.
Start driver installation with printer USNB unplugged, the printer setup wizard will tell you when to connect the printer to computer.
Set the printer as default when asked.
HP2601xi says I need software when I push the scan button
Uninstall the printer then reinstall it. the software went bad,biut it wil have to uninstall first. The other option is to disconnect and uninstall within windows itself, the reinstall.
k24674
Grand Canyon Tech
Grand Canyon Tech
