20 Most Recent
HP Photosmart 2610xi All-In-One InkJet Printer Questions & Answers
How do you make an enlarged print copy?
Try scanning it into your computer as a .jpg file. Cpen the file and click of the image to activate it. Grab a corner block and drag it to the size you want then print.
I dont have the CD Install. Sory I lost. I
Hi friend.,
Simply visit the website bellow to download the appropriate drivers.
Select your operating system and then download and save to your desktop the available driver.
Open the file you downloaded and fellow the instruction on your screen to install it.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=421134&lang=en&
Hope this solution works for you.
Paper jammed when loading paper,
Welcome to FixYa.
To clear the paper Jam, follow the steps below.
1. Remove all loose paper from the paper In tray.
2. Do not pull paper jam from under the front cover.
3. If there is more than one sheet stuck in the printer, remove the paper sheet at a time.
4. Make sure no scraps of paper are stuck in the printer.
5. If there is open the door at the back of the printer.
6. Pull the jammed paper out of the printer.
7. Check again to make sure no scraps of paper are stuck in the printer.
8. Close the back door.
9. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
When printing, paper pulls to one side
It will pull to one side if the rubber roller on that side is coated with dust or is used up on some parts.
1. Clean the roller with some alcohol & soft cloth
2. if the above solution does not solve ur problem, pls replace that part - contact hp
The power supply is no longer working on my
if there is no power and you think that the cord is ok, then the problem there is internal if the cost of the repair is somewhat high better buy a new printer to avoid loss time
HP Photosmart 2610xi is printing but it does not
You need to clean the encoder strip, that's the clear strip that runs behind the carriage assembly, you can clean it with a Q-tip damp with alcohol, the strip is fragile so don't press too hard. If you look with a flashlight you should see the area that needs cleaning.
How do I save a scan as a pdf?
you scan normally and save as .pdf,if i remember right there is a option scan to pdf search in the menu that apear on screen.
Not receiving fax - notes is error 410* prompts
Hi! I will be glad to assist you in this issue. here is the link to fix the issue.
Interpreting Error Codes in Fax Communication Error or Fax History Reports:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=421139#Error396
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02151&cc=us&lc=en&dlc=en&product=421139
Error Message on screen
Check two things
1. Ink in your catridge
2. Check whether the catridge has been proprely inserted because some movement to the printer may cause the catridge postion to be misplaced
Hope your problem got solved
Please rate my solution
Thank you
