SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
SOURCE: lost manual for new sylvania lc420ss8
http://www.sylvaniaconsumerelectronics.com/pdf/manual/LC420SS8.pdf
nice TV . heres the manual.
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
SOURCE: remote code for att uverse to sylvania lc320slx lcd tv
My solution might be a little off because I called Comcast for the answer but it seems that the problem is that the code doesn't exist.
I called Comcast and they had no clue. But I called Sylvania and their
reps were FABULOUS!!! Turns out, the TV makers send the cable companies
the frequencies for each TV then the cable companies send them to a 3rd
party to get the codes written.
This model of TV is new and there is no code written. The rep suggested
that we countinue to check back on the Comcast website regularly to see
if the code is posted. She said that the sales reps tend to get the
info last.
The Sylvania rep anticipates a new code written soon because this is such a prevelant problem.
