The set is detecting moisture inside the set somewhere--either put it somewhere dry or I have taken some apart and dry with a hair dryer---it could also be nothing as I have seen a few where the dew sensor was at fault.
You could try http://www.mauritron2.com/service_manuals.html or http://www.mauritron2.com/operating_guides.html We've used them in the past and found them very good.
But u still have and pay for the basic cable service wright?Yes,just used the tv remote and push the remote menu button than go into the tv menu,go into Setup enter and go down and pick CABLE not AIR.Enter for the tv do scanning for cables channels.After finish scanning u will get all the basic cable channels.
Hello, As far as I examine this model on the web,I discover that your TV has the following features as:
Feature: Combination TV/VCR featuring 13-inch TV and 2-head mono VCR
Feature: Front AV input jacks for game system; 181-channel tuner for access to unscrambled cable broadcast
Feature: 1 video, 1 audio (mono) input in front; RF coaxial antenna input in back
Feature: Mono output and built-in speaker; headphone jack
Model: MV13M2
This means that you do not have "A/V output" jack to complete your desire.. Sorry about it.. Take care and please Remember to rate/vote and give me 4 Thumbs Up for Helping out the Community :) Hope this helps!
This TV is an older model with an NTSC tuner (OTA and CATV (analog). You will need a set top box with the digital cable system.
The law didn't require ATSC tuners in 13" TVs until 2007 and the TV was listed at Amazon in 2002. The law requiring the digital transition didn't pass until 2006.
Please rate! $20 for a NEW remote is fair. There are some cheaper universal remotes from the big box stores but you then have to program it. Some of these universal remotes are tricky with combo units. A new remote would be ready to go out of the box. Most of Toshiba's products have a manual online than can be viewed, downloaded, or printed off.
I hope my tip helps you in finding the right solution. Many universal have codes there ether 3 or 4 digits depending on what brand of the universal you got.
Let us know if you have any other questions. please do be considerate and leave postive feedback and ratings. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
hold down vol down on the remote and push 1 on the universal remote. this should turn your tv off and reset it to factory defaults alowing acess to all cable channels
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
BWLY
This is a known issue with this TV. The following might resolve it:
Check Mute and Volume:
Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume.
Inspect External Speakers:
If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues.
Test Different Inputs:
Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box.
HDMI Troubleshooting:
If the issue persists with the DVD player over HDMI, consider the following:
HDMI Cable: Check the HDMI cable for damage or loose connections.
Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary.
Mainboard Replacement (if needed):
If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard.
TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
There may be loose contact or track open in main board.So try to check the main board thoroughly where you may find the loose of connection or track open.
Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
Serial numbers don't work Judy
https://www.google.com/search?q=A10A13799C3300
They are purely a numerical identifier of when it was made, year, day, number on the shift, whether it Joe or Billy who did final inspection.
With a MODEL number I can find them easily with just 'make model manual'.
Toshiba
http://www.toshiba.com > support > content
PDF
Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please.
62 pages
Toshiba
PDF
Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please ...
62 pages
