Garden Logo
Cindy Oleksiak Leander Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Snowblower stalls without reason and now makes a squeeling noise. craftsman 8.5 hp model 536.891851
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
  • Posted on Jan 23, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1512752
Points
12435
Check the drive belts at the engine for wear or damage. It could also be a bad bearing at some point in the auger/impeller or wheel drive. Try to pinpoint the source of the noise and what you do that makes it squeal. Good luck!
2answers
What is the auger belt size for craftsman snowblower model C950-52151-1?
https://www.google.com/search?q=C950-52151-1&rlz=1C1CHBF_enUS757US757&oq=C950-52151-1&aqs=chrome..69i57.655j0j4&sourceid=chrome&ie=UTF-8
My snowblower isn't starting
If it's the starter that makes a humming noise then you need to check the starter out. the gears could be stripped or even a tooth missing so it won't grab the fly wheel. Try pulling the start rope and see if that makes a difference. My Craftsman 8 horse has a recoil starter as well and I quite often use it as well. I don't always use the electric start.
1helpful
Model # 627804x79a. Spirit snowthrower. How much oil does it take?
Hard to tell how much oil to put in new snowblower ...
www.shopyourway.com > Manage My Life > Questions
Jan 14, 2012 - The manual states that the snowblower has an oil capacity of 20 oz and it ... How much oil do I need to put in my Craftsman model 917.388122 ...Missing: 627804x79a ‎spirit
Where can you get skid plates for Spirit 8 hp 27 Model ...
www.answers.com > ... > Gardening > Lawn Mowers and Garden Tools
Where can you get skid plates for Spirit 8 hp 27 Model 627804X79A snow blower? Where can ... What viscosity oil does a 5 hp techumsen yardmaster snow blowerrequire? My 5hp ... How much hp does a 205cc Briggs and straton ohv snow blowerengine have? ... Take the cap off that nipple and tip back to drain the old oil.
Nov 24, 2015 • Garden
Mower stalls
make sure belts arent around the guides to keep the belts on.
does it smoke or make any other noise
why did yu change all the parts
2helpful
3answers
Craftsman riding mower will not start
Same thing happened to me with my 26 horse kohler craftsman. Replaced EVERYTHING (spark plug, fuel filter, oil filter, and degunked the carborator), and still was flooding. It ended up being the flywheel key. Cheap part, quick fix. I guess it can happen when you hit something hard with the deck, or it can just happen without reason... I hit a snowbank hard with my snowblower attachment, but I didn't even realize it until afterwards because it kept running fine. Supposedly, even after the strain to the engine, it won't always stall out. It will keep running (but maybe rougher) until you shut it off. Then when you go to start it again, you will have no luck because all the timing is out of whack. It cost me $80 to have a repair company fix it. I think the part was only $5.
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
1helpful
Snowblower manual
Not sure if your looking for a parts manual or a user manual but if you go here you can find the parts manual:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=536.885921
Dec 21, 2008 • Garden
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
