20 Most Recent Craftsman 24 Hp 48" Deck Yard Tractor Questions & Answers
Need a belt diagram for a 48" cut craftsman fs5500
Yes
7/27/2021 5:47:03 PM • Craftsman 24 Hp... • Answered on Jul 27, 2021
Have a 23hp craftsman garden tractor with kohler engine no wiring
on most starter switches the back of the switch is labeled which wire goes to what
1/21/2018 1:54:57 PM • Craftsman 24 Hp... • Answered on Jan 21, 2018
Crfsmn DLT3000 w/18.5hp OHV Intek plus mower model
pull the plug and see it it turns freely possible hydraulic lock in the cylinder
11/8/2017 10:00:26 PM • Craftsman 24 Hp... • Answered on Nov 08, 2017
Started craftsman lawn tractor 24 hp kohler engine
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
11/5/2017 3:07:56 AM • Craftsman 24 Hp... • Answered on Nov 05, 2017
Carburation springs on the CV740S KOHLER ENGINE where do they go.
I would have to look at it.
6/29/2017 2:15:35 AM • Craftsman 24 Hp... • Answered on Jun 29, 2017
2answers
21hp b&s white smoke
drain engine oil an refill to manuel capacity, its easy to overfill this model due to the dipstick tube height
5/19/2016 1:05:26 AM • Craftsman 24 Hp... • Answered on May 19, 2016
Why is the engine firing up through air intake
Sounds like your timing is out..or the valve slap needs adjusted..When this happens the inake valve is partly open during the firing stoke allowing some of the exaust to go back through the intake..and out the carb..good good luck
3/17/2015 7:49:08 AM • Craftsman 24 Hp... • Answered on Mar 17, 2015
2answers
Routing Of Deck Belt For DLT 2000 48 inch Deck
It can be found on amazon, here... take a look Amazon com DLT 2000 belt. I hope this was helpful. Have a nice day
12/15/2014 3:11:01 AM • Craftsman 24 Hp... • Answered on Dec 15, 2014
Changing drive belt
need model number.
9/22/2014 7:05:30 AM • Craftsman 24 Hp... • Answered on Sep 22, 2014
How do you unstick idler pulley
do you mean stuck as in the pulley doesnt turn? or stuck as in the arm that the pulley is attached to will not pivot? if its the pulley, replace the pulley. If its the lever, you will probably have to clean dirt or debris from between it and the cutting deck.
9/19/2014 8:33:02 PM • Craftsman 24 Hp... • Answered on Sep 19, 2014
Why can' I t get mower to do anything when trying to crank it over?
try jumping your battery with your car/battery. If that works, charge your battery and/or adjust your valves. If it doesnt, try jumping directly to the starter from the battery. If that works, get a new starter solenoid. If it doesnt, get a new starter.
9/18/2014 4:42:49 PM • Craftsman 24 Hp... • Answered on Sep 18, 2014
How to fix the blade engage pulley
need more info. if it seems loose and wobbly, you need to replace it. If the whole arm is not moving, it may have grass or dirt between it and the deck...clean it out. if its not dissengaging or takes a long time to dissengage, you may need to re attach the return spring.
9/18/2014 2:56:13 PM • Craftsman 24 Hp... • Answered on Sep 18, 2014
4answers
Engine will not turnover
Is it a Briggs or Kohler motor,and since it is a 24 hp I take it it has overhead valves.3 thousand on the valves semms awful tight unless it has hydrolic lifters.I always set both intake and exhaust at 5 to7 thousand. will it turn over by hand with no plugs in ?does it lock up when using starter ? (look at starter shaft bent)I know this sounds stupid but are both pistons moving freely or is connecting rod blown.You could have a bent valve stem.
9/11/2014 12:47:51 AM • Craftsman 24 Hp... • Answered on Sep 11, 2014
Need a diagram for all 3 belts on a 48'' craftsman lawn tractor
need model number. usually under seat.
9/5/2014 8:44:21 PM • Craftsman 24 Hp... • Answered on Sep 05, 2014
How to replace belts
need your model number. usually under the seat.
9/5/2014 8:30:08 PM • Craftsman 24 Hp... • Answered on Sep 05, 2014
2answers
Losing power
I take it its a Briggs motor It sounds like 2 possibilities 1 possible half sheared flywheel key causing out of time conditions 2 carb is dirty not due to your new gas filter but dirt through air inlet and needs to be taken off diassembled and cleaned (carb cleaner and determine all jets and small orfice holes are clean.
8/11/2014 3:24:36 PM • Craftsman 24 Hp... • Answered on Aug 11, 2014
Where is the PTO switch?
The switch is on the dash bezel, the electric clutch is on the deck. Some clutches can be adjusted but I need the model number of your mower first.
7/21/2014 7:03:50 PM • Craftsman 24 Hp... • Answered on Jul 21, 2014
I have a pgt 9000 that keeps blowing 20 amp fuse
You have a short to ground. Look for places the wiring goes through metal housings.
7/21/2014 6:13:03 PM • Craftsman 24 Hp... • Answered on Jul 21, 2014
Craftsman 24 Hp 48" Deck Yard Tractor Logo
354 questions posted
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
routing deck belt dlt 2000 48 inch deck
  • Garden
