20 Most Recent
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Questions & Answers
Turn on mower engine dies and carburetor floods.Deck isclean to and bottom.
If your engine stops and then the carburetor floods, your needle and seat is not closing correctly. This can be caused by dirt or varnish being caught in the needle and seat.
A good clean with some carburetor cleaner will remove any dirt or varnish buildup from the carburetor. Then while you have it apart give the float a shake to see if it has a leak.
If there is any liquid in the float you will need to replace it.
Won't move forward
bad check valve in hydrostat does motopr have normal power i asume it does
Need to know how to check the trans axle cooling,
There is no way to check the level without removing the trans. These transmissions are sealed for life.Was there a leak? If there were no leaks, don't worry about the level. If there was a leak you should have a qualified tech check the fluid level.
