Husqvarna 450 e-series 18" Chain Saw Logo
Posted on Jan 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not pumping oil - Husqvarna 450 e-series 18" Chain Saw
Plink-plonk
Level 3:
  • Husqvarna Master 1,807 Answers
  • Posted on Mar 07, 2015
Plink-plonk
Husqvarna Master
Level 3:
Answers
1807
Questions
Helped
818719
Points
15648
Check oil pump, oil pump drive gear, and rubber oil guide tube isnt blocked
1helpful
On a 2006 chevy colorada 2.8 4cyl.truck how do you change oil pump
Removal Procedure
Remove the engine front cover. Refer to Engine Front Cover Replacement .
Remove the oil pump cover bolts.
Remove the oil pump cover.
Mark the inner and the outer gears in relation to the oil pump housing.
Remove the inner and the outer oil pump gears.
Remove the oil pump pressure relief valve plug.
Remove the oil pump pressure relief valve and the spring.
Clean and inspect the oil pump. Refer to Oil Pump Cleaning and Inspection .
Installation Procedure
view youtube videos
3answers
It is not pumping engine oil
You need a working oil pump to pump the oil around the engine. If the oil is not being pumped through, the oil pump has failed or there is a blockage in the lubrication system.
Most likely the oil pump has failed and needs to be replaced.
Do you have to drop the engine to replace oil pump in 2007 gmc yukon
You have to remove the engine front cover (over timing chain) and remove the oil pan to get the oil pump in and out. You don't have to remove the heads, however.
Removal & Installation
4.8L, 5.3L, 6.0L & 6.2L Engines
Fig. Exploded view of the oil pump mounting-4.8L, 5.3L, 6.0L and 6.2L engines
Fig. Oil pump disassembly-4.8L, 5.3L, 6.0L and 6.2L engines
  1. Remove or disconnect the following:
    NOTE
    Do not allow dirt or debris to enter the oil pump assembly, cap ends as necessary.
    NOTE
    The internal parts of the oil pump assembly are not serviced separately (excluding the spring). If the oil pump components are worn or damaged, replace the oil pump as an assembly. Do not attempt to repair the wire mesh portion of the pump and screen assembly.
    Engine front cover Oil pan Oil pump screen bolt and nuts Oil pump screen with O-ring seal. O-ring seal from the pump screen. Discard the O-ring seal. Remaining crankshaft oil deflector nuts. Crankshaft oil deflector Oil pump bolts
    Oil pump To install:
    NOTE
    Inspect the oil pump and engine block oil gallery passages. These surfaces must be clear and free of debris or restrictions.
    1. Align the splined surfaces of the crankshaft sprocket and the oil pump drive gear and install the oil pump. Install the oil pump onto the crankshaft sprocket until the pump housing contacts the face of the engine block.
    2. Install or connect the following:
      NOTE
      Lubricate a NEW oil pump screen O-ring seal with clean engine oil.
      NOTE
      Push the oil pump screen tube completely into the oil pump prior to tightening the bolt. Do not allow the bolt to pull the tube into the pump.
      Oil pump bolts. Tighten the oil pump bolts to 18 ft. lbs. (25 Nm). Crankshaft oil deflector
      NEW O-ring seal onto the oil pump screen
    3. Align the oil pump screen mounting brackets with the correct crankshaft bearing cap studs.
    4. Install or connect the following:
      Oil pump screen Oil pump screen bolt and the deflector nuts. Tighten the bolt to 106 inch lbs. (12 Nm) and the nuts to 18 ft. lbs. (25 Nm). Oil pan Engine front cover
Replace oil pump in 94 grand am
the 2.3 and 3.1 engines need to drop oil pan.for the 3.3 engine you have to remove timing chain cover.you have to remove oil filter adapter the pressure regulator valve and the valve spring.then remove oil pump cover to oil pump screws remove cover remove oil pump gears.when installing another new oil pump lubricate the oil pump gears with clean engine oil pack the pump cavity with petroleum jelly.torque oil pan cover screws to 97 inch lbs which would be 11 ft lbs torque.oil filter adapter plate 24 ft lbs.
2helpful
Replacing Oil pump in Ford Expedition
the oil pump is on the crank behind the balancer and timing chain cover:
REMOVAL
1. Remove the timing chain.
2. Remove the oil pan.
3. Remove the three (A) oil pump screen and cover bolts and the (B) oil pump screen and cover.
4. Remove the two oil pump bolts and the oil pump.
INSTALLATION
1. Clean and inspect the mating surfaces.
2. Install the oil pump and loosely install the two oil pump bolts.
3. Install the oil pump screen and cover and install the three oil pump screen and cover bolts.
4. Install the timing chains.
5. Install the oil pan.
How to replace oil pump on 2004 bmw 545i
M62 ENGINE TURN OFF RADIO FIRST. YOU NEED TO INSTALL A MEMORY SAVER BEFORE DISCONNECTING NEGATIVE BATTERY CABLE. TO KEEP FROM LOSING PCM MEMORY. TO REMOVE OIL PUMP.YOU NEED TO LOWER OIL PAN.REMOVE THE LEFT AND RIGHT ENGINE MOUNTS AT THE BOTTOM.REMOVE POWER STEERING PUMP AT THE HOLDER.REMOVE OIL PIPES AT THE POWER STEERING PUMP ALSO ON AUTOMATIC TRANSMISSION, REMOVE BANJO BOLT FOR THE OIL RETURN PIPE FROM THE OIL FILTER AT THE OIL PAN.REMOVE THE MOUNTING BOLT ON THE SPROCKET FOR THE OIL PUMP AND REMOVE THE SPROCKET ALONG WITH THE CHAIN,REMOVE 3 OIL PUMP MOUNTING BOLTS AND REMOVE THE OIL PUMP.REMOVE THE OIL PIPES OUT OF THE CRANKCASE. BEFORE INSTALLING NEW OIL PUMP, CHECK SEALS ON THE OIL PIPES AND REPLACE IF IT NECESSARY.LUBRICATE THE SEALS WITH OIL AND THE OIL PIPES.CHECK THE SEAL IN THE OIL PUMP AND REPLACE IF NECESSARY, SCREW THE HEXAGON ADAPTER BACK INTO THE OIL PUMP UNTIL IT STOPS.INSTALL OIL PUMP AND 2 RIGHT SIDE OIL PUMP MOUNTING BOLTS .TORQUE BOLTS 14 - 17 FT LBS. POSITION THE CHAIN ON THE PUMP AND SPROCKET AND INSTALL THE SPROCKET.TORQUE BOLT TO 35 FT LBS VERIFY THAT THE CHAIN IS POSITION CORRECTLY. ADJUST THE CHAIN SAG TO 0.315 - 0.472 INCHES 8 - 12MM BY TURNING THE HEXAGON ADAPTER IN THE OIL PUMP, THEN INSTALL THE LEFT SIDE MOUNTING BOLT. INSTALL OR CONNECT THE FOLLOWING. INSTALL BANJO BOLT FOR THE OIL RETURN PIPE FROM THE OIL FILTER AT THE OIL PAN, INSTALL THE POWER STEERING PUMP AND CONNECT THE OIL LINES IF EQUIPPED.INSTALL LOWER OIL PAN, INSTALL THE ENGINE OIL.INSTALL THE NEGATIVE BATTERY.
4helpful
2answers
REMOVAL & INSTALLATION
Gasoline Engines
See Figures 1 and 2
Fig. Fig. 1: Exploded view of the oil pump used on 2.0L and 2.3L gasoline engines
Fig. Fig. 2: Exploded view of the oil pump used on the 4.0L engine-2.8L and 2.9L engines are similar
  1. Follow the service procedures under Oil Pan Removal and remove the oil pan assembly.
  2. Remove the oil pump retainer bolts and remove the oil pump.
To install:
  1. Prime the oil pump with clean engine oil by filling either the inlet or outlet port with clean engine oil.
  2. Rotate the pump shaft to distribute the oil within the pump body. Install the pump and tighten the mounting bolts to 14-21 ft. lbs. on 2.0L and 2.3L engines; 6-10 ft. lbs. on 2.8L and 2.9L engines or 13-15 ft. lbs. on 4.0L engines.
Do not force the oil pump if it does not seat readily. The oil pump driveshaft may be misaligned with the distributor shaft assembly. To align, rotate the intermediate driveshaft into a new position.
  1. Install the oil pan as previously described. The oil pumps are not serviceable. If defective, they must be replaced.
Remember rated this.
2helpful
Oil pump ,,,where is the oil pump located on a 1997 dodge caravan
Hello
Welcome!
Oil pump is located on the oil pan.
Parts needed,,,oil,,,, oil filter,,,, oil pan gasket,,, oil pump,,,, oil pump pickup tube..
time to do this,, about 3 hours
Instructions,
Raise van place on 2 jack stands
drain oil remove oil filter fill new filter install.
remove bolts from oil pan,
remove oil pan..
remove 2 bolts that hold oil pump and tube.
install new pump and tube tork bolts to 45 fp
replace oil pan gasket and install oil pan
tork pan bolts to 35" pounds
install drain plug
fill with oil
start and check for leaks
let me know if i can help more
I am having a problem after warm up and at idle speed the oil pressure drop low enought to trigger the check gauges light. I have been trying to trouble shoot the problem with oil changes etc. but it is...
4.3L Engine To Remove:
    • Engine oil pan
    • The oil pump
    • Inspect the pins (oil pump locator) for damage gm_truck_43_ol-pmp_loctr-pns.gif
      1. Replace the pins if required
  2. Clean and inspect all parts.
To Install:
  1. Inspect for properly installed pins (oil pump locator). Note: Do not reuse the oil pump driveshaft retainer. During assembly, install a new oil pump driveshaft retainer.
    • The oil pump
      1. Position the oil pump onto the pins
    • The oil pump bolt attaching the oil pump to the rear crankshaft bearing cap
      1. Tighten the oil pump bolt, Torque to: 66 lb ft (90 Nm)
    • The oil pan
2answers
OIL PUMP
This Depends on a 2 Details, ENGINE Size 4by4 or NOT. Most are Fairly Simple Once the Oil Pan has been Removed and the OIL PAN is Normaly the HARDEST Part of it
AFTER OIL PAN REMOVAL
  1. Remove the oil pump. Refer to Oil Pump, Pump Screen and Deflector Removal.
  2. A loose screen or pipe assembly can result in an air leak and loss of oil pressure. For more information, refer to Oil Pump Clean and Inspect.
INSTALLATION PROCEDURE
  1. Install the oil pump and the oil deflector. Do not reuse the oil pump drive shaft retainer (4). During assembly, install a NEW oil pump driveshaft retainer. Refer to Oil Pump, Pump Screen and Deflector Installation.
  2. Install the engine oil pan. Refer to Oil Pan Replacement
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
