American Standard Cambridge 5' Americast Bathtub w/ Grab Bar Drillings & Le Logo
Posted on Jan 09, 2011
Sewer smell just started in my main floor bathroom. Bubbling sound in the bathroom of that room for the past couple days only when I frush the tolit. If it is the main line, what do I do? Phone someone like Roto Rotor rather than a plumber? Thanks
Anonymous
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Jan 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
17668
Points
41
Most plumbers have a roto ruter and more knowledge you may have a plugged or faulty vent
3helpful
2answers
Sewer smell in house from septic tank and idle system
If the house has been sitting for a long time, the traps may have dried out and are not stopping the sewer gasses from being trapped back, flush all toilets and run some water in all the sinks and tubs, to refill the p-traps, also don't forget to pour some water down the washer drain pipe. HOPE THIS HELPS...
Nov 10, 2014 • Plumbing
1helpful
3answers
How can we get rid of the occasional sewer smell in our house?
When you next get the smell, check the traps to see if there is enough water in there to fill the trap, if one is less then it looks like water is getting sucked out when toilet is flushed or that trap (usually bath or shower) hasn't had water going in (lack of use) and water has partially evaporated.
Sep 06, 2014 • Plumbing
1helpful
I being plagued with sewer gas how can i stop this
sewer gas is stopped by water in the drain. often three drain I. the floor dries out. or your drain is not holding water. pour water into all your drains. .
Nov 01, 2013 • Plumbing
1helpful
Sewer smell drain
are there any floor drains in the room and an unused bathtub or shower? if so the water may have evaporated from the trap and allow the sewer gas smell. try pouring water into all the drains and see if it is still happening. more elaborate problem may be a broken vent stack in a wall.
Apr 23, 2013 • Kohler Home
1helpful
2answers
Bathroom sink smells strongly like sewer when water runs fast.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
Oct 15, 2012 • Plumbing
2helpful
2answers
Sewer gas smell in bathroom.
Sounds like you have an intermittently blocked vent pipe (the one that goes out through your roof). If there is gas pressure in the downstream sewer line and it can't get up through the vent, it could bubble up through your toilet or sinks. I would get up on the roof with a few jugs of powerful drain cleaner and dump them into your vents. You might also run a few dozen gallons of water down those vents after the drain cleaner has had time to work.
Oct 05, 2012 • Plumbing
2answers
Sewer smell in house since installing the new toliet and the toliet gurgles when the washing machine is on. It started with the new toliet now the gurgling and smell is also present in another bathroom.
It sounds like a vent problem.
On top of each house is a vent stack.
There should be a vent stack above each toilet, and above kitchen sink.
Look for pipes sticking out of roof.
These pipes are open to the sewer line.
When you run a column of water down a drain, the vent stack lets air flow in front of and behind the column of water.
This air flow prevents the gurgling sound.
The gurgling sound is the drain water pushing air in front of it because of a clogged vent.
If you have a two story house, there are vents that run between floors to prevent the air flow from gurgling or bubbling sewer air into each drain as water column moves down pipe.
http://www.bradyinspects.com/plumbing-vents.html
http://chestofbooks.com/home-improvement/construction/plumbing/Standard-Practical/Venting-Part-3.html
Look for bird nest over vent pipe on top of house.
Run a snake down into pipe from roof and see if the is a stoppage.
You many need to call plumber to track down each vent and the cause.
For example if there are quick-vents installed inside a wall and the quick vent is no longer working.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
2answers
Basement plumbing. I want to put in a basement bathroom and my plumbing drain from the house is 4' from the basement wall. I need to put in a sewer basket and venting. any diagrams to follow?
My suggestion is to build up the floor where the tub will be maybe 12" above original floor and u can make a couple steps up to the tub the whole length of tub
Dec 10, 2010 • Home
6helpful
Fowl smell in bathroom
Fowl smells related to plumbing can have several causes. Here's a few potential issues that you can check. If none of them solve the problem you may need to call a plumber.
1) Look at your pedestal sink drain connection. Is there an an elbow connecting to your drain or a P Trap? A p trap is a pipe shaped like the letter "p" (hence the name) and it prevents sewer gas from rising into the bathroom. **sometimes an apprentice plumber puts in a pedestal without a p trap because they are fairly difficult to install, and ALL fixtures need P traps. If there is no P trap, then you need to put one in. It will be a tight space, but you may be able to do it yourself.
2) Do you have a floor drain? If so, your sink will need a trap primer at the drain. Or you can pour water into the drain from time to time before it evaporates from the trap
3) If the smell is more of a sulfur type smell and it appears from running water in other places in the house, then it could also be due the type of tank you have if you are on well water
My offhand guess is that number 1 is your issue.
Without further info, those are some of my best solutions so far, but if none of these are potential solutions, then make the following tests
1) close the door to the bathroom and leave it for an hour or two. Return to the room. Do you smell sewer smell? Is it in the entire room or more concentrated in a certain area? If you don't have a floor drain and its everywhere, there could be a missing P trap from a fixture, a lose toilet flange, a cracked drain pipe
2) without running water, smell your drain. Does it have a sewer smell? Then the P trap either is not present or you need to clean the drain with a drain cleaner due to a list of reasons
3) run water. does the sewer smell increase or does one suddenly appear. Is the smell more a different odor than sewer. See if it is the water itself. If so, check other places. If they do not have the smell then you may have recently installed your sink and there is some smell related to the new valve. Then you would need to use it some more until it disappears.
Check the top list, though because I really think you're just missing a P trap
Sewer breaks below the slab, an open pipe somewhere, some issue with the water supply, are among some other issues but that depends on the test
Top American Standard Plumbing Experts
john h
Paul Carew
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
