20 Most Recent American Standard Bath Faucet Ceramix 2000.500 002 Chrome Bath/Shower Fauce... Questions & Answers
When shower faucet apart make sure hot is getting 2 & coming out faucet ***. did you turn off stop integral w/ faucet or outgoing shut off valve on water heater.. May have rust or lime in small orifice leading to faucet ***. does your balancer/ piston move freely..good luck..
American... | Answered on Mar 24, 2011
replace gaskets, and hot & cold water stems inside of manifold (turn off water first).
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
American... | Answered on Jul 11, 2010
That is a type where the water is mixed inside the valve and the valve has gotten worn or loose inside. Replace it or take it apart to see what isn't working properly.
American... | Answered on Apr 12, 2010
Follow this link for the mixing valve adjustment
http://common.csnstores.com/common/marketing/americanstandard/asd6420_installation.pdf
HTH,
Mike...
American... | Answered on Dec 02, 2009
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
American... | Answered on Dec 26, 2008
Hello Matg55,
If the seat came out with the stem, you will need to reinstall it.
The valve's disc needs a seat to seal properly.
Is the seat threaded on the side opposite the bevel?
Do you have a seat removal/Installation tool?
Kind Regards,
IT_handyman
American... | Answered on Dec 17, 2008
Download the BILT app and search for your faucet model. The icon is turquoise with a white nut ( as in nut and bolt).
It will show you step by step nearly everything under the sun. Hope that helps a bit.
American... | Answered on Nov 09, 2019
No, sorry but if it used to work it is unlikely to fail so soon. Check the hot water supply first.
American... | Answered on Sep 29, 2019
I need 300 2go credit in my 2go account
American... | Answered on Jul 23, 2019
Make sure that the compression nut is not too tight where it could bind up the plunger rod. I'm sure you have probably gotten up under to see if it is hitting anything. Also, make sure that the lift rod is adjusted correctly. I am leaning more towards the unit being bound up some how.
American... | Answered on Dec 10, 2018
Never use Draino on a toilet. All pipe cleaning liquids are not really a solution, just a temporary fix.
Since you said that the slow draining is associated with both the toilets and the sinks then I am almost certain that you have a venting issue.
Imagine a drinking straw.....now if you hold your thumb on the end of the straw and bring it up abouve the water level water remains in the straw. This is because air can't get in to replace the water. When your finger is removed then the water flows freely.
As with the straw, your plumbing must also breath. I would bet that one or more vents that are on your roof have become clogged with debrise. Squirrels love to throw nuts and stuff down there to build their nests upon.
Climb up there (safety is a priority) and try running a snake (~$10 at lowes) and see if you hit any obstruction. If so, use the snake to dislodge it.
If you would like, pour water down the vents either by hose or bucket and see if the water backs up. If it does then you have a clog. You can also use the water to try to clear the clog.
Thanks.
American... | Answered on Nov 27, 2018
The faucet may have gotten clogged during the changeover process but it could simply be defective.
American... | Answered on Nov 26, 2018
mixing valve and ceramic washers are defective. American Standard is not what it used to be. Parts are substandard and imported from china. Get yourself a Glacier Bay, and contact American Standard and demand your money back or a credit.
American... | Answered on Sep 27, 2018
American Standard Bath Faucet Ceramix 2000.500 002 Chrome Bath/Shower Fauce... Logo
Popular Tags
24 questions posted
Top American Standard Plumbing Experts
Thomas F. Schneider
john h
Fahr Quad
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Plumbing
Most Popular Question
adjust anti scald valve american
  • Plumbing
