The inverter board is easier to change and the least expensive, but I would check your cable connections from the motherboard to the monitor. Have you tried hooking a external monitor to the video output on the back of the laptop to check for picture? because I assume your laptop is working, but if it's not It would be a motherboard problem. If you can provide more information that narrows the scope down and helps me to help you.
Connect the laptop to an external monitor, if image comes on it means it's the LCD screen, if same thing happens then it's the inverter.
