SOURCE: Flashig lights, ticking sound, unfinished cycle
It sounds like it may be a heater problem or motor start problem. If you will post the complete model number from the decal, I may be able to look up something on it.
You should be able to get warranty service even without the proof of purchase as long as the manufacturing date proves it is within the warranty period. The date code is in the serial number.
If you will post it also I can look it up and tell you when it was built.
Thanks/Mike
SOURCE: the dishwasher won't turn on
sounds like a problem with the door iterlock switch most of them have a small micro switch when you shut the door it activates the system quite easy to do but can be a bit fiddly
SOURCE: the buttons on the dishwasher won't push and let
Try completing the last cycle till end. Check the user guide and there
will be a master reset operating procedure. You may have to operate
the keys in sequence as mentioned in the guide manual.
Good Morning friend, thanks for your post!
From the information you have provided the door gasket on your Frigidaire dishwasher continues to come loose. Typically, when your gasket starts coming out you may need to have a replacement gasket installed. I would recommend operating the gasket you need from your manufacturer and replacing it. I hope this information is helpful. -Matt
Hi Kenneth Cho - I will suggest verifying that there is enough water pressure coming into the unit. Is the unit making a grinding noise? If it is, then the dishwasher seems to have a defective drain motor. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Hi Charles - From what you have described it sounds like there is a miscommunication with the control board/panel and you will need to contact a professional to diagnose it for repairs.
