20 Most Recent Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Questions & Answers
I had the same problem. I pressed the "Start Cancel" button, kept it down, then pressed "Rinse Only" button. The display then went clear. I pressed "Start Cancel" again, then "83" showed up on the display. I let it run its cycle, then it corrected itself. A little scary, but it worked. This answer board is great!
Frigidaire 24... | Answered on Jul 07, 2019
So far so good. I fixed mine by removing the vent and even though it says no repairable parts I disassembled it then removed the rubber gasket and cleaned it with a brush under hot water. I then cleaned the plastic ring it seals against. Next I removed the spring and stretched it to make it about a quarter inch longer and then reinstalled the spring then the rubber gasket and then closed up the unit. So far it is working fine. I suspect the real problem is that there is a tiny sensor that needs to be covered when the vent is closed. If this is not covered the uo error code is generated.
Frigidaire 24... | Answered on May 10, 2019
Good Afternoon Friend,
I understand your Frigidaire dishwasher, model# PLD3465REC, will not start. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire 24... | Answered on Jul 08, 2014
Good Morning Friend,
I understand that you are receiving a CO code on your Frigidaire Professional Series dishwasher, model# PLD3465REC. C0 means that there is some type of communication error. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire 24... | Answered on May 29, 2014
Good Afternoon Stacy,
I see that you are having trouble with your Frigidaire dishwasher, model# FGHD2433KF1, showing an error EU. I also see that you have had a technician out who stated that there was no vent inside the unit. I would start by contacting the manufacturer, to see if you are in warranty, and if not, if there is any assistance they can provide to you. Hope this is helpful.
-Best Regards-
WP
Frigidaire 24... | Answered on Apr 22, 2014
Hi Mark, thank you for your post!
Error code UO commonly means that the vent is in an open position. While your Frigidaire dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly.
Before reaching out to a professional, let's try resetting your dishwasher. This can be done by flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn your dishwasher on. This often clears most false-error codes. If resetting the power does not correct the issue, a professional will need to check the wiring between the vent assembly and main control board.
Best of luck!
Frigidaire 24... | Answered on Feb 01, 2014
Hello Orland, I am happy to assist you. I understand you are seeking information on where to purchase a particular part. Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor).
May I please have the model number? You can typically locate the serial tag on the right side as you open the door. With this information I can better assist you in providing you the correct part number on the circulation motor for your dishwasher.
Thank you and I look forward to your response.
Frigidaire 24... | Answered on Aug 19, 2013
Hello - Are you referring to the spray arms will not rotate? If so, do you noticed if the spray arm is cracked or broken? Will it rotate slowly? If so, you might have to remove and replace the spray arm assemblies. I will suggest verifying that there is enough water pressure coming into the unit. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board or wiring connections to the dispenser, I would suggest contacting a professional technician to diagnose the unit accurately.
Frigidaire 24... | Answered on Nov 28, 2012
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
91 questions posted
Top Frigidaire Dishwashers Experts
Mike
Vitally Alcher
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dishwashers
Most Popular Question
error message er frigidaire dishwasher
  • Dishwashers
