Hello Caron, thank you for your inquiry!
Based off the information you have provided you took apart the bottom panel of your Frigidaire dishwasher and need help reassembling it. I have attached a parts schematic of your dishwasher to help assist you further. Best of luck! -Matt ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/5995552584.pdf ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/5995552584.pdf
Thank you for your post, Sheri!
Based off the information you have provided your Frigidaire dishwasher is giving you longer time cycle then what you select. Inside of your dishwasher there is a soil sensor, when the water comes into your dishwasher the sensor picks up on the amount of dirt inside of the tub and will adjust the time if need be. You may need to perform a reset on your dishwasher and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help correct the issue you may need to replace that sensor or you could have a short within your control panel and that may need replacement. You may want to contact a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
Hi friend, thank you for your inquiry!
I understand that the panel on your Frigidaire dishwasher has lights on the far right side of the panel. I would recommend a reset on your dishwasher and you can do that by flipping the household circuit breaker in the off position for ten minutes. The lights on the right side of the panel could be providing a warning to inform the panel that something is wrong. A reset could provide an error code for further diagnosis. I hope this information has been helpful. -Matt
11 questions posted
438 Questions
252 Questions
192 Questions
187 Questions
117 Questions
