First you'll need to turn on your Wi-Fi.
1. Choose (Settings) then (WiFi) then (turn WiFi on)
2. Set iPod touch to ask if you want to join a new network: Choose (WiFi) and turn (Ask to Join Networks) ON or OFF.
Then you'll need to join a WiFi network (your D-Link for instance)
1. Choose (Settings) then (WiFi) then wait until your D-Link shows up in the list of networks.
2. Select your network and if you have a password for your router make sure you type it. (networks that require a password have a lock icon next to it) then tap (join)
Once you join a WiFi network manually, iPod touch will automatically connect to it whenever the network is in range. If more than one previously used network is in range, iPod touch joins the one last used.
When iPod touch is connected to a WiFi network, the WiFi icon in the status bar at the top of the screen shows the connection strength. The more bars you see, the stronger the connection.
Good Luck
SOURCE: Can't connect my Ipod touch to my router?
i had the same problem too with my'n. My issue was on of my setting's was set to block that wi-fi connection. Try switching your setting for finding internet connection from automatic to manual. that should do the trick!
SOURCE: ipod touch
Basically, all you have to do is turn the WIFI "on" on the iPod Touch. And it will connect to your wireless router. If you have a security key, it will ask you to type it in. See Pages 26 and 90 in the user's guide:
http://manuals.info.apple.com/en_US/iPod_touch_2.2_User_Guide.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: my ipod touch wont connect to my buffalo router
Try a different kind of wireless encryption on your router. This will probably fix it. If your password is wep, try wpa. If it's wpa, try wep. If you don't know what the heck I'm talking about.....let me know :)
SOURCE: have a d-link router with password. Ipod touch(8G) won't connect
Try remove the password on D-Link router, put it on open conditions (no security enabled).It should work.
If still won't connect, try using laptop or any wireless device to connect to router(without password), if connect, then there's something wrong with your Ipod.
