20 Most Recent D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n Questions & Answers
Maybe you have the wrong 192... Go command prompt and type in "ipconfig" without the quotes. scroll up and find the default gateway (default gate way . . . : 192...) and type that in your browser and press enter.
If that doesn't work, go to your network connections and right click on the one that is connected click properties, click on Internet Protocol Version 4, click properties, and make sure all the settings are automatic. Restart computer, repeat first part.
If that doesn't work, reset your router and access point. Than reconnect and repeat first part.
D-Link DAP-1522... | Answered on Jul 28, 2018
Connect your computer to the router.
Assuming Windows 7, click the "Start" button.
Into the search-box, type 'CMD' and press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
D-Link DAP-1522... | Answered on Apr 20, 2016
These answers on all these sites are very confusing. Here's what I did to solve the issue of not connecting with a browser. 192.168.0.50 does not work nor does http://dlinkap.local. or whatever else is printed on the device. On my PC that is hard wired to my router, I logged into my router, checked which wireless devices were connected and found that dlinkap (note this is not the SSID that is printed on the device) was assigned 192.168.0.4. Set my browser to 192.168.0.4 and off we go to configure the extender.
D-Link DAP-1522... | Answered on Jun 07, 2015
From your computer, get the MAC-address of your network adapter.
Configure the router to always give out the same IP-address for that MAC-address.
D-Link DAP-1522... | Answered on May 11, 2015
You posted your question in December 2013.
Do you still need an answer?
D-Link DAP-1522... | Answered on May 07, 2015
If it is under warranty, contact the manufacturer, and get it replaced.
Access D-Link's support-site: ftp://ftp2.dlink.com/PRODUCTS/DAP-1360/
Choose 'REV. A' or 'REV. B' or 'REV.C'.
Download the instructions for your router.
It should work "out-of-the-box".
Be sure to connect using "straight-through" (not "cross-over") Ethernet cables.
Connect from the 'WAN' port on the router to your DSL-modem (or cable-modem).
Power-off the DSL/Cable modem.
Power-on the DSL/Cable modem.
Power-off the D-Link.
Power-on the D-Link.
Reboot your computer.
You should be good.
Click on reset button and hold it about 20 second after some your router will be reset .
D-Link DAP-1522... | Answered on Jan 29, 2015
Hey Rolando,
On the back of the unit is a small button to reset. Use a straigtened paperclip to do so. Attached is an image of what it should look like. b86d4bfe-0100-4d89-87bc-74360b9790d9.jpg
D-Link DAP-1522... | Answered on Jun 06, 2014
If the page does not open then you don't have a connection to the router. Make sure your cable is attached to the router and computer. You can't do the initial install wireless usually.
D-Link DAP-1522... | Answered on May 01, 2014
Setting up a wireless router with a Windows client can be complicated.
There are a number of measures and options that have to be understood, and it's all too easy to make a mistakes but D-Link provides an easy to walk through configuration system to help you set up your D-Link wireless router.
Plug one end of the Ethernet cable into the DSL modem.
Then plug the other end into the "WAN" port on the back of the D-Link wireless router.
Connect wired computers to any of the other Ethernet ports on the router using another Ethernet cable.
Access the D-Link Configuration Screen
Open your web interface and type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
Use "Admin" as the username and leave the password blank when the login screen appears.
Click "OK." You should now see the D-Link configuration screen.
Set Up General Security
Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button.
Enter a new password under the "Administrator" heading.
Confirm it, and click "Apply."
Disable the wireless Local Area Network (LAN) if you don't need to use the wireless access and you want to make sure no one else is able to access your network.
Under the "Home" tab, choose "Wireless" and select the "Off" option.
Enable Wireless Encryption Protocol (WEP)
Locate the "Home" tab in the D-Link Configuration screen, and click on the "Wireless" button.
Use the "Open System" button beside "Authentication."
Select the "Enabled" button next to "WEP," and set the encryption key to "128 bit."
Set the "Key Type" to "ASCII" and choose a 13-digit password for the "Key 1" field.
Write down the password in a secure location.
Click "Apply." Change the SSID
Change the SSID to make it more difficult for others to locate and use your network by clicking on the "Home" tab and locating the "Wireless" button.
Change the default SSID to one of your choosing, then click "Apply."
Disable SSID broadcasting. Under the "Advanced" tab, click on "Performance" and check off the "Disabled" box. Again, click "Apply."
Filter MAC Addresses
Click the "Advanced" tab in the D-Link "Configuration" screen and select the "Filters" button.
Choose the "MAC Filters" and click on "Only Allow Computers with MAC Address Listed Below to Connect to the Network."
Enter the name and MAC address of the computers allowed to access the network, beginning with the one you are currently configuring. Click "Apply."
D-Link DAP-1522... | Answered on Mar 20, 2014
There are a number of measures and options that have to be understood, and it's all too easy to make a mistakes--but D-Link provides an easy-to-walk-through configuration system to help you set up your D-Link wireless router.
Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button. Enter a new password under the "Administrator" heading.
Click "Apply."
Change the SSID
Click "Apply."
If you have forgotten this password, you will have no choice but to reset the router to factory defaults.
Reset Procedure: With the router powered on, Press and hold the reset button (on the back of the router) for 10 seconds and release. The lights on the front of the router should all flash and reboot.)-
D-Link DAP-1522... | Answered on Mar 11, 2014
To reset the router password you have to locate the reset button on the back of the router. While the router is turned on, press and hold the reset button for 10 to 15 seconds. Once released the router should reset. After reset, go to http://192.168.1.1
You should be able to login using new password.
D-Link DAP-1522... | Answered on Feb 04, 2014
D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n Logo
Popular Tags
34 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
cannot access either dlinkap or
  • Computers & Internet
