Pls advice me on how to download other devices after reformat the PC from the net cause at the moment the sound, internet & other devices is not functioning
If you want to download from the same PC then you cant as the Ethernet driver will not be installed ..
if it is installed then you can download ....
check it in the
control panel>system(switch to classic view in case of XP)> hardware>device manager
in device manager go to network adapters there if the Ethernet driver is installed then you will be displayed there (if the driver is not installed then you will not see that network adapters also)
if it is not installed then you must download the Ethernet driver from some where else to your system from your manufacture(motherboard or chipset manufacture) website (if it is intel then http://downloadcenter.intel.com in this website you can search it & download)
if you have the Ethernet driver installed then you can download from your system only the other drivers from the manufacture website ....
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution as per your satisfaction
Download here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
First select windows system.
Next the driver and hit global for download.
Unzip the file before you install.
VERY GOOD
Sir
Pls advice me on how to download ethernet controller the PC from the net cause at the moment the sound, internet & other devices is not functioning.
Thanking you
i need to download and install ethernent controller
for toshiba sattellite A80
need to know how to download pci device driver for a ga-vm900m motherboard...that's the only driver that has not installed after the pc format,
pci device driver for ga-vm900m
ygjrf
Download here:http://www.gigabyte.com/products/product...
