20 Most Recent
Compaq Presario R3000 Notebook Questions & Answers
Burning DVD
Impossible, since your device _reads_ CDs/DVDs, but does not _write_ either CD nor DVD.
Do you have a USB memory-stick (holding 4Gbytes) ?
If so, copy the files to the memory-stick,
and take the memory-stick to your friend's computer,
presuming that his/her computer has a DVD-writer.
That DVD can be _read_ on your computer.
DVDs Choppy playback
its not a error, your computer is just slow, try using vlc media player to play a dvd and tell me if it plays better
Blue characters on the keyboard when I type
It is a combination of key known as "Function" (Fn, for short). You have to press it and hold while pressing other keys showing the blue letters on it. The most common use is to make a virtual Numerical Keypad on laptops, so you can perform calculations. To be back to normal mode, you need to press FN+F8 (or the key with the Calculator icon).
My screen does not turn on
- Remove all power (adapter power Cord and Battery (for laptops))
- Hold down the ON button for 30secs (dispersing internal voltage)
- Plug the power cord in only (ie leave battery out, for the moment)
- Turn on
Check your power adapter. Plug it in to a known good power receptacle. See if the power adapter has any lights that light up to make sure it is getting power.
Take the battery out of the laptop and just only plug in the power adapter.
Do any lights on the laptop light up when you power it on? Does it beep?Does it make a sound? Is where you plug your power adapter to your laptop loose or broken?
if no sound or light the its either power adapter , dc jack or cable, or system board .
Please note, it is also a good measure to re seat the memory.
You may need to locate your disassembly guide
How do I restore factory settings
The simplest way is to fully re-format the Hard Drive. Boot to any Windows installation CD or DVD, and when the option comes up, choose to install a new copy of Windows, and follow delete existing partitions and re-format HD options. For extra security, don't select "fast format". End this dummy installation after this formatting procedure. The most secure method for data deletion however is a bit more physical. Remove the hard drive and smash it with a hammer! You'll know the drive is well and truly trashed when you can here bits clanging around in the drive casing when you shake it.
Compaq presario v5000 dark screen and failing hard drive
The problem you described, is related to the inverter board.
There's a little board, that take care of lights on the monitor. You must replace the inverter board to solve the problem.
Here you have an image, of an inverter board.
Good luck, and be safe!
Inverter boards, it's dangerouse to replace yourself if you don't know what you are doing. High-Voltage inside :)
