With digital camera pretty well taking over from the film cameras a lot of film cameras just sit and the batteries become corroded which leaves a nasty white power in the battery compartment. Your camera takes two CR123A batteries these need to be in the correct orientation or it just won't work.
Look down into the battery compartment and make sure the contacts are clean and without corrosion. I've used lens cleaner on a cotton swab to get down in there and clean it off, don't get it dripping wet just moisten the swab a bit at a time. When there is a badly corroded point then a small bit of sand paper taped to the end of a pencil has worked for me in cleaning up the bad terminal.
Hopefully you don't need to go through the cleaning process and it's just that you have the batteries in incorrectly.
