20 Most Recent
Kodak EasyShare M320 Digital Camera Questions & Answers
My Kodak EasyShare M320 Digital
Check the contacts for the battery. They may be rusted / making poor contact. Did you leave a leaky battery in there for some time?
If you can get an Emory board or small file in there it might help to clean up the contacts. If clean, try bending the clips up to make a stronger contact with the battery.
Lens error lens continually coming in and out.
Common problem, these lenses elongate with a set of gearing and close tolerances. Lots of times sand and dirt get into the mix so the gears don't mesh and they get bound up.Hold the camera firmly in one hand while off and smack it into the palm of your other hand to dislodge some of the dirt then do the same thing alternately along each different axis. Try turning on the camera after each few smacks do not hit anything hard with the camera. This worked for me and has worked for many people, just keep doing it and turning the camera on and let it go thru its start up sequence over and over.Good Luck !
Kodak easyshare m320 charge light is green, but not charged
Hello Dead Battery, Well this sounds pretty easy compared to most questions I get. If the camera says the battery is dead, then the battery is dead !! the problem with batteries is they loose their capacity over time. The charger can not put any more in it and says it is charged. Just get a new one and give it a full charge and this should do the trick.Best Regards, Russell
Kodak easyshare m320 froze and won't turn on
Send it back to Kodak, these models are nothing but trouble, far to many customer complaints, Made in China and not made very well, not dependable, Try a better brand. Kodak has seen better days with their products. Buyer Beware
Down load on windows 7
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Camera wont turn on
1) memory card slot/battery cover is open2_ batteries are load with polarities wrong fix it3) batteries are NOT same type, fix it4_ insufficiente loaded battery, replace by full charge5) poor contact between camera and battery terminal, adjust and clean.with isopropyl alcohol.use the common sense, and logicallyGod bless you
How do i email photos
There should be an "attachments" option where you type your emails to be sent. Then you choose where the pics are stored on your computer
Downloading from m320 to computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
