20 Most Recent Kodak Easyshare M753 Digital Camera Questions & Answers
Hi
This may be the problem with ur CCD .Very rarely optical unit problem. anyhow visit a service centre.
Kodak Easyshare... | Answered on Nov 13, 2015
Hershey, take a small pair of needle nose pliers and try and wiggle the lens and it should work! I just did it with my daughters camara
(Same camara, same error message) Good luck!!
Kodak Easyshare... | Answered on Dec 07, 2014
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2.
Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera.
Thank you !!
Kodak Easyshare... | Answered on Nov 07, 2014
Every rechargeable battery has a certain cycles of charging and discharging the battery. Not two batteries have the same life time. The amount of cycles a battery can have, can be influenced by the user. If you leave a battery without charging or discharging for months or even years, the lifetime can be shortened. That is why most of the time you get warranty on the equipment, but almost never on a battery. (sometimes a warranty of 90 days is given on a battery.)
Still when a battery won't charge, you could check all the parts in the chain. The AC / DC power convertor / charger the power cable.
When the light on the charger comes on, you can assume the charger is working.
If you can charge the battery in the camera everything looks the same. As soon as the green light comes on (starts to flash slow) you can assume the AC adopter is working. The charging of a fully discharged battery should take about 4 hours.
I have two Kodak Li/ion batteries and after almost 10 years, they are still on good condition. But I also had to trow away lots of other batteries, before they were about one year of age. (I did charge them wrong, with a high current, more then they could handle)
Kodak Easyshare... | Answered on Aug 26, 2014
The battery life is quoted as 250-350 pictures in auto mode. This would be for a new battery and camera and it is likely that the number of recharging cycles on a 7 year life will have led to some deterioration in the battery life. The two links below take you to pages from which you can download the Users guide and getting started guide in a pdf format.
http://www.manualslib.com/download/348740/Kodak-M753.html
http://www.manualslib.com/download/89260/Kodak-Easyshare-M753.html
Good luck
Kodak Easyshare... | Answered on Aug 25, 2014
it not reading data via usb try taking memory card out and putting it into your computer then try
Kodak Easyshare... | Answered on Jul 19, 2014
need to go to shop to clear fault needs a specialist attention
Kodak Easyshare... | Answered on Jun 17, 2014
Replace the camera with Ebay purchase or upgrade. Not something that is fixable at a reasonable cost.
Kodak Easyshare... | Answered on Jun 07, 2014
Try to press the button on top, with the two logos, and make sure you did put the camera in Smart Capture mode. It should work fine then. If it still does not work, contact your dealer, or a certified Kodak service centre.
Kodak Easyshare... | Answered on Jun 03, 2014
this is not much to go on. If I would have the camera in my hand, perhaps I should see more. Like if there was a scene on the display, after I switched on the camera.
If everything else looks ok with your camera, pleas look if your camera is still in the Smart Capture mode. Press the button on top of the camera, with the two camera logos on it (still and video camera) en use the arrow up and down keys on the back, to goto the Smart Captuer mode. When there, the camera should work correct. Most of the time, your camera is caught up in a scene mode, like beach scene, and does not have enough light to focus and therefore does not take a picture. It also could be in the video mode, without you knowing.
Success
753 has a special mini usb cable only from kodak-buy a 20.00 sd memory card reader and use that to download-they work great!
Kodak Easyshare... | Answered on Jul 22, 2013
Kodak Easyshare M753 Digital Camera Logo
406 questions posted
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
kodak easyshare share m753 39 ve
  • Cameras
