IS it the right key? Did it work before? If it worked before then you might have some debris in the lock itself causing the key not to seat properly. Is it a new key? If it is the right lock and key, perhaps the key has worn and you have to "jiggle" it a little - insert the key all the way in and gently try turning it, if it won't turn, withdraw the key a tiny amount at a time while gently trying to turn the key - it may take several trys to find the "Sweet Spot" for the key to work. Sometimes new keys are "too new" and have sharp edges where the key was cut. Take the key back to any key maker and ask them to burnish the key again. It sometimes helps to lubricate the lock mechanism with some graphite (you don't generally want to use oil as it can collect dust and make a goo inside the lock. If you do use some lubricant (like WD-40) in the lock to clean it and get it to work, you might want to flush it out with Isopropyl alcohol and then put some graphite (or silicon lubricant) into the lock to keep it turning smoothly.
You will need an internet connection and wireless router. Turn on your DS and access the system settings by tapping the "wrench" icon. Next, tap "Internet Settings". Tap "Connection Settings." Tap "New Connection." Tap "Manual Setup." Tap "Search For Access Point." The DS will search for wireless networks within range and display the networks that it finds. Try to be close to the router when you do this, it helps the DS find the network. A picture of a lock will appear next to each router found. Locate yours. If the lock is open tap your network name and then tap "ok" to save the settings. Tap "ok" again to begin a connection test. If it is successful, you are now connected. If not, search the nintendo website for your error code and it will assist you. If the lock is closed, select your network name and a keyboard will appear. Type in your WEP/WPA key and tap "ok" when finished. Tap "ok" to save the settings. Tap "ok" again to begin a connection
Are you trying to lock it so no one can connect to your network, or lock it so that no one can access the setup? If you're trying to make it so no one can connect to your network, go to your router setup page(192.168.1.1). If you haven't changed the password for the setup page, it should be Username: admin Password: password. Look for Wireless Security, and add a WEP key. Once the router resets, your computer will ask for a key to connect to the network. Just type in what you made the key and you'll be connected.
If you want to lock it so nobody can change the settings, you'll need to do that from the settings page just like last time, except this time look for Administration. Usually it's one of the last tabs. In there you'll see the administrator password. Just change this and you'll have it locked.
Perhaps your network at home is open (doesn't need a network key) and the one at work has to have a network key (password) and you are not able to supply. Networks are normally protected from outside connections by the administrator that locks it up with a network key. Check with whomever set up your work network. If your home network is open, you may want to discuss with that person how to protect your home network.
You need to have a wifi connexion at home that you can connect to. You will need the wep or wpa key ( a protection code for your network) that was programmed in your router so that you can connect to the network. If you do not have a router or a wireless connection at home, you can only connect with a network cable.
Without any wireless networks available, using your computer wirelessly is most pointless. If you want to set up a wireless access point in your home you need a wireless router, connected to Internet.
Your computer is asking for the WEP key which is the security key setup at installation so anyone who wants to enter your network must know the password. Check the simple things first, like your CAPs Lock key is off, Num Lock key is off, double check you are typing in the correct password. You can change the WEP key with the software that came with the wireless installation.
Before you attempt
to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP
key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi
providers have this information on their web site or when you purchase
access you will be provided the information.
Ensure you have a firewall program installed and running. This will protect your data.
Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
Click on the Wifi Connection icon on bottom right of screen and you
should see a window that indicates connection, strength and duration.
Click on the Properties tab.
The next window will show the type of networking card installed. Click on the Wireless Networks tab.
Once the Wireless Network Connection Properties window is open you
will have two options depending on how you set up your laptop.
If you
do not see any networks listed in Preferred or Available networks, you
will have to manually add the SSID. Click on Add.
You will have to enter the SSID and WEP key (if required). Click OK and
you should then see the network you just added in the Available
networks box.
If you see the correct SSID showing in the Available Networks, then
you need to click on Configure in order to enter the WEP key if that is
required.
In the next window, enter the SSID for the Wi-Fi network you want
to access. Make sure you do not have CAPS lock or NUM lock while
entering the information. If a network key is required, click on "Data
Encryption and then enter the Network key you have been provided with.
Again make sure you do not have CAPS or NUM lock on. Click OK when
entered. If you have entered the key incorrectly a message will pop up
and you will need to re-enter the key.
Next go to Start - and where it says Connect To click on that and
you should see choices like in the graphic below. Click on Wireless
Network Connection and it should work.
There are
occasions when the connection doesn't work, in these cases check your
firewall software and make sure it allows you to connect to the Wi-Fi
network. To check this, disable your firewall software and check the
connection again. If you can connect with the firewall program
disabled, you change your settings. If your firewall program is not the
problem check the SSID and WEP key information that you entered. Both
of these are case sensitive. If you had obtained SSID information from
the Internet, check with someone in the establishment to see if the
SSID has been changed.
I finally discovered the problem. I have a Linksys wireless
router, so when I tried to log on with my iTouch, I got the
message "Unable to join network "my network name" when
I typed in my password. One day, after many trys, I tried
typing in the network security key for my router, and Voila,
it worked. For some unknown reason (to me), the iTouch
recognizes the the network security key as the password.
