20 Most Recent Acer Aspire 6930-6771 Laptop Questions & Answers
3answers
I want to buy a laptop in price range of 40,000rs
I HOPE YOU DIDNT BUY THAT COMPUTER OR ANYTHING UNTIL YOU READ PCWORLD FEBRAURY 2009 ISSUE,
IT HAS RATE FOR VEDIOS CARD, TECHNICAL SUPPORT, BUYING NEW COMPUTER, HP HAS THE WORST RATING IN THE COMPUTER MARKET,
PLEAASE READ THIS ARITICAL FIRST, START ON PAGE 82 THUR PAGE 92
ROD THE CANDYMANGANDY
2/12/2018 8:30:35 AM • Acer Aspire... • Answered on Feb 12, 2018
My Acer Aspire 6930 will
Have you tried rebooting the device?
2/5/2018 2:53:21 PM • Acer Aspire... • Answered on Feb 05, 2018
2answers
Cant reboot acer aspire 6930
so you aspired does boot but the OS does not? What OS? Try safe mode. Very likely a video driver related issue.
1/7/2018 6:19:01 PM • Acer Aspire... • Answered on Jan 07, 2018
Wireless connection fails on acer E1-571
Wireless problems can have various causes. Do other devices in your network work fine (other notebooks, smartphones)? And have you tested your Acer in other networks, like in a friends house, etc? If your notebook fails anywhere you use it, it may have a faulty wireless adapter (altough that's very rare). I would try to remove and reinstall the wireless driver and if that don't solve it, reinstall the OS (you could also have a virus problem). If the notebook works fine in other places, it could be your wifi router. Try turning it off and on.
12/19/2017 11:35:45 AM • Acer Aspire... • Answered on Dec 19, 2017
How do I turn on or install the wireless drivers
Another option, because your notebook's built-in wifi hardware is provided by Intel, is to head to https://www.intel.com/content/www/us/en/support/detect.html using the notebook, and install and run Intel's Driver And Support Assistant (Intel DSA) which should then advise you what Intel drivers are needed for your Aspire 6930.
10/8/2017 5:09:21 PM • Acer Aspire... • Answered on Oct 08, 2017
Acer Aspire 6930 when start up won't go pass the black screen
Try to boot in safe mode which version of operating system you installed
12/20/2016 9:24:11 AM • Acer Aspire... • Answered on Dec 20, 2016
I have an older Acer Aspire 3000... it recently
Not all systems are supported by Windows 7. Infact many items that were supported by vista are not supported in windows 7.
looking at your system specs you woudl originally have AMD Mobile Sempron 3000+ / 1.8 GHz , 256mb ram and windows xp home as your original.
this system does not meet the minimum requirements to run Windows 7 Ultimate or Windows 7 at all.
minimum specs for windows 7 are
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • i do not recommend a 1ghz system. i would recommend a 2ghz or better with 2GB of memory for a basic version
    4/21/2016 11:44:14 AM • Acer Aspire... • Answered on Apr 21, 2016
    Change brightnes
    easy if its touch screen swipe to the right and a little boarder comes then click settings,,brightness and bam you done or you can do it on your keyboard on the arrow keys(there should be a sign) or go to settings and click screen resolution,,then brightness
    3/13/2015 12:40:46 AM • Acer Aspire... • Answered on Mar 13, 2015
    Restoring acer 6930 to factory default
    Before you do this understand it will delete everything currently on your drive ! so save important files if you can !! try holding the"Alt" key and the "F10" key when the computer is booting up. This should give you the option to restore to factory settings.
    3/2/2015 4:30:09 PM • Acer Aspire... • Answered on Mar 02, 2015
    Aspire 6930 HDMI output shows only part of picture. Used to work correctly.
    change the settings in the display adaptor for the HMDI. They may also be accessible in the display icon of the control panel.
    10/13/2014 11:45:21 AM • Acer Aspire... • Answered on Oct 13, 2014
    11answers
    Acer Aspire 6930 wifi will NOT turn on when the button is pressed
    start Windows Mobility Centr from the Accessories program group in the Start menu..you will see if its connected or not connected on top right hand side of pop up screen. Just click to turn wireless on and off. Otherwise go to page 14 of the Generic User Guide for more infor.
    7/7/2014 12:33:12 AM • Acer Aspire... • Answered on Jul 07, 2014
    0answers
    Diagram wiring
    Be the first to answer 4/18/2014 9:45:10 AM • Acer Aspire... • Posted on Apr 18, 2014Be the first to answer
    0answers
    0answers
    0answers
    Cant watch netflix
    reset browser from settings, delete temp files, try again.
    12/16/2013 11:04:15 AM • Acer Aspire... • Answered on Dec 16, 2013
    4answers
    I have acer 6930g laptop and the screen starts
    Permanent Fix for your Aspire 6930 shaking screen problem, .
    I had a very bad shaking screen for weeks in a row and it drove me creazy, the solution is quite simple and you can fix it yourself !!
    The whole problem is a kinda loose monitor conection inside the Laptop. Because of open and closing the laptop screen the conection comes off.
    All you need to do is open the Laptop, disconect the cable and put it firmly back again, problem solved.
    If it happens again, repeat this but now also put an plastik tape over the whole cable so that it cannot can come off again.
    When needed more info or how to do it, just send me a mail, at NO cost I will send you pictures how to do these things.
    Greetings, [email protected]
    11/21/2013 1:23:18 AM • Acer Aspire... • Answered on Nov 21, 2013
    Acer Aspire 6930-6771 Laptop Logo
    253 questions posted
    Steve Sweetleaf
    Steve Sweetleaf
    Grand Canyon Tech
    Grand Canyon Tech
    View Most Popular
    Aspire Acer
    • Aspire Acer
    Most Popular Question
    disable keyboard from typing only green
    • Computers & Internet
